 NW Iowa | If the actual speed holds and the readout is jumping around
it's more than likely your radar.
Look at your % slip. You can unhook it and see what it does. It will read 100% slip but the speed should hold.
If your actual speed slows on its own. I would look real hard at your shuttle and swap it out.
I have a spare on the shelf.
It could also be your console stick.
You can calibrate the stick, but not the shuttle.
If your readout is steady but the actual speed is off,
do a speed calibrate.
All this is in the service book.
Edited by Massey1155 7/8/2025 10:26
