Hypothetical running over crop while spraying?
shulerfarm
Posted 6/14/2025 12:20 (#11261478 - in reply to #11261298)
Subject: RE: Hypothetical running over crop while spraying?
Holly Hill, SC
I was curious of the same thing and went ahead and drew out 3 scenarios on Auto CAD, 90 degree to row, 30 degree to row, and parallel to row. Assuming 100' boom on 30" row spacing and 12" tire track. Rectangular field 1/2 mile (2640') x 1/4 mile (1320'). Rows planted long direction. Ignore the perimeter pass since that would be consistent for all three.
90 degree: 24,200' driven over, 25 passes
30 degree: 24,956' driven over, 23 passes
parallel assuming run over 2 rows per pass: 60,696' (Could cut this in half if the wheel width is adjusted so it is not possible to run over two rows at once.) 12 passes
Obviously the best scenario would be to drive between the rows and run over zero.
Edited by shulerfarm 6/14/2025 12:23
(20250614_131756 (full).jpg)
(20250614_131907 (full).jpg)
Attachments 20250614_131756 (full).jpg (109KB - 45 downloads)
Attachments 20250614_131907 (full).jpg (63KB - 28 downloads)
