Search Forums | Classifieds (106) | Skins | Language
need to update computer that runs quicken 2011 home & business
JRosenberger
Posted 5/5/2025 20:16 (#11215159 - in reply to #11214994)
Subject: RE: need to update computer that runs quicken 2011 home & business
Milford, IL
Easiest solution - if you like Quicken 2011 and want to avoid the software as a service business model - when it comes time for new, keep the old PC exactly as it is, disconnect it from the internet, and continue on your merry way.
Quicken 2011 has a low likelihood of working with Windows 11 - you could run it inside Virtualbox set up for W10, provided the software does not need online activation or activiation is relatively easily circumvented.
I don't think it would be best to buy a new off the shelf PC with Windows 10 OS. 10 isn't going away tomorrow, but support from software developers will taper eventually.
