Search Forums | Classifieds (82) | Skins | Language
2nd unmanaged switch slowing internet speeds?
golfnut
Posted 11/10/2024 13:11 (#10961109 - in reply to #10961008)
Subject: RE: 2nd unmanaged switch slowing internet speeds?
Central Nebraska
It sounds to me like you have a duplexing issue with the second switch.  Try a different cable between the two and/or try using different ports.  Generally, switches ports are grouped together and I've seen several times where half a switch worked perfect and the other half poorly or not at all.  Generally this is only on switches with 8 or more ports.
