Search Forums | Classifieds (4) | Skins | Language
Removing tractor or combine tires from the rim
neukm
Posted 9/14/2024 12:19 (#10890065 - in reply to #10889560)
Subject: RE: Removing tractor or combine tires from the rim
EC IL
Definitely not NAT approved..
Remove wheel and lay on concrete floor..use backhoe to break beads on both sides. Pry first sidewall over the rim, use backhoe to dangle wheel and have gravity do the job. Much easier than trying to fight a vertical wheel.
