Running feed numbers..
dabeegmon
Posted 7/31/2024 11:08 (#10833740 - in reply to #10833375)
Subject: RE: Running feed numbers..
SE Manitoba
garvo - 7/31/2024 06:37
balance rations in my head says that is something is under $100 a ton lets find out the feed value in cost's per lb compared to corn
corn is 7cts a # or $140 ton
very rare we get into 2 to 3cents a # $40 to $60 ton
I have bought a lot of by products that cost $100 ton that have in a mixed ration enhanced my corn
quick math says you roll on products under $100 ton-add or subtract moisture to adjust at 1% per moisture point
most nutritionist have not feed cattle
So - - - would you be buying the 'stuff' or not if you were looking at it?
(Inquiring minds want to know - - please?)
TIA
