| Hi all. And Happy Holidays. Today I am looking for any info on this Case trailer plow. I know it is a 2-14"s plow. I had to remove what was left of the old rims. I believe it may have been on steel and was made to fit the old rims. There was nothing left of them. I took the lift mechanism apart and cleaned and re-greased it all. It works perfectly. I need help in setting it up. I plowed a little with it. I think I may need to adjust the hitch side to side. Also, it doesn't seem to want to suck in very deep. It seems the hitch runs at too high an angle. To the point, I think it is being lifted on the front. The tail wheel is solid mount with not much depth adjustments. The hitch is solid mounted. It is as high as it will go. Unless, I think I could turn the frame mounts over and maybe gain a couple inches. I accidentally put the traction tire backwards (depending on who you ask) but it works. So, leaving it. I think these pics should help. Thanks in advance.
(20231222_133801 (full).jpg)
(20231222_133748 (full).jpg)
(20231222_133724 (full).jpg)
(20231222_133634 (full).jpg)
(20231222_133706 (full).jpg)
(20231222_133624 (full).jpg)
(20231222_133616 (full).jpg)
Attachments ---------------- 20231222_133801 (full).jpg (203KB - 146 downloads) 20231222_133748 (full).jpg (165KB - 149 downloads) 20231222_133724 (full).jpg (116KB - 158 downloads) 20231222_133634 (full).jpg (171KB - 159 downloads) 20231222_133706 (full).jpg (176KB - 154 downloads) 20231222_133624 (full).jpg (199KB - 142 downloads) 20231222_133616 (full).jpg (225KB - 134 downloads)
