NW IA | A bit of the decision was due to location, this point allows easier access from another part of the yard. Terrain was also a factor, as the ground falls off pretty severely to the west. The last factor is sometimes you get all of the other equipment in the rear of the shed, and all that remains is the "rectangle" at the front of the shed. You need a couple of short, wide somethings, which isn't always the easiest to wedge in. Thought is we can pull a semi, folded planter, or something else long and narrow in at the end and finish filling the space. I'm sure sometimes it won't make sense, but hopefully sometimes it will too. | |
