Search Forums | Classifieds (15) | Skins | Language
John Deere 4010 LP Tractor
valleyfarms
Posted 12/10/2010 20:04 (#1478833)
Subject: John Deere 4010 LP Tractor
Michigan
I found a JD 4010 LP tractor in rough shape, it is worth spending the time to rebuild? Are they rare?
tommyw-5088
Posted 12/10/2010 21:50 (#1479018 - in reply to #1478833)
Subject: Re: John Deere 4010 LP Tractor
Texas
I thought they were , but found out later they are somewhat common .
We paid 5700 with a good 148 loader on the tractor .
It is a handy tractor , but not much collector value .
A LP powershift would be more rare .
Tommy
Mark (EC,IN)
Posted 12/10/2010 21:57 (#1479027 - in reply to #1479018)
Schlegel Farms, Hagerstown Indiana
Would have to be a 4020 to be a PS.
4010's never were offered that way.
...........Mark
Gerald J.
Posted 12/10/2010 22:05 (#1479035 - in reply to #1478833)
There were 3721 gas 4010, 5268 LP 4010, and 48,583 diesel 4010 made. So less than 10% of 4010 production was LP, less than 6.5% were gas.
Gerald J.
tomram486
Posted 12/10/2010 23:34 (#1479241 - in reply to #1479035)
I had a 4010 that I bought. I did not know they made any gas 4010s. Never saw a LP version, but not surprised. I bet that gasser sucked gas. learned something, today.
Gerald J.
Posted 12/11/2010 01:30 (#1479342 - in reply to #1479241)
Probably not quite as much gas as a gas 4020 because the 4010 gas engine is smaller. The gas 4020 does consume fuel, but for its day the 4010 was the biggest JD tractor made. And it uses a lot of hydraulic power. Worse there's no extra ignition advance for part throttle operation and that hurts a lot. You need another ten degrees advance for half throttle economy and power. One time I changed my pinto wagon from centrifugal plus vacuum advance to centrifugal only (the only distributor I could mail or telephone order after I broke the original playing with it the milling machine looking for a squeak). It ran great at full throttle while accelerating but was doggy run gently and sucked gas.
According to Larsen's book on that vintage Nebraska tractor tests, the 4010 gas did 9.26 hp-hr per gallon, the LP did 7.59 hp-hr/gallon and the diesel did 12.38 hp-hr per gallon. So at 80 hp developed that's 8.64 gallons per hour gasoline, 10.54 gallons LP per hour, or 6.46 gallons diesel per hour.
The PS 4020 did 11.77 hp hr /gal on diesel, 7.79 hp/hr /gal on gasoline and 7.42 hp hr/gal on LP. For 88 hp that's 7.47 gal/hr diesel, 11.3 gal/hr gasoline, and 11.86 gal/hr LP.
They made 7290 early 4020 gas, 844 late 4020 gas. 7606 early 4020 LP, 839 late LP. 115,010 early diesel, and 54,168 late diesel. They made 299 4000 gas (stripped and lighter weight 4020) and 7796 diesel. The total production 4000 and 4020 was then 8433 gas, 8445 LP, and 176,974 diesel. Total was 193,852 4000 series tractors. Production numbers came Jan Feb 2008 2 cylinder magazine where somebody sat down and counted from the production logs. The logs didn't discriminate between transmissions so those splits are unknown.
Gerald J.
tommyw-5088
Posted 12/11/2010 09:48 (#1479602 - in reply to #1479342)
Texas
Gerald J. - 12/11/2010 01:30
Gerald J.
Im not good on gas engine spark ing. ,where could a person get the dist to cure the problem ?
My 4010 lp burns more fuel than anything i have ever been around
Cnat keep fuel it it .
Tommy
