Search Forums | Classifieds (132) | Skins | Language
JD 4255 hydraulic motor return
superfarmer
Posted 4/8/2009 20:51 (#673937)
Subject: JD 4255 hydraulic motor return
Eastern Ontario
Where is the best place to return the hydraulic motor oil on a 4255 Deere? I've used the fitting on the left side of the remote before, but I'm installing a hydraulic sprayer pump that will be run continuously, so I wondered if there was a better place to return to. Thanks.
silagehauler
Posted 4/8/2009 21:04 (#673949 - in reply to #673937)
Subject: Re: JD 4255 hydraulic motor return
This is how I set up my 4640 to run a hydrualic motor on a tub grinder. Seems to work pretty good.
Photobucket
Photobucket
Edited by silagehauler 4/8/2009 21:06
superfarmer
Posted 4/9/2009 06:43 (#674325 - in reply to #673949)
Eastern Ontario
That's probably what i'll do, but someone told me there was a better port to dump the oil to. Thanks anyway!
Tommy
Posted 4/8/2009 21:25 (#673985 - in reply to #673937)
Subject: RE: They make a special tip
Iowa
There is a special tip that doesn't have the restrictive spring-loaded ball/tip on the end of it that will plug right into your outlet and allow plenty of flow--been doing it that way on a 50 series for 15 years.
Earthworm
Posted 4/10/2009 00:42 (#675441 - in reply to #673985)
Archer Iowa
There is a plug you remove on the back on the case. You need an adapter to go to a pioneer coupler and then use a special tip with no ball and spring in it. I believe the plug is on the right half on the back of the case.
