Posted 3/9/2009 21:36 (#637866) Subject: Info for old Commercial Intertech Hydraulic Pump
ND
We are trying to mount a pump on our 936 Versatile to run the fan motor on our air cart. We pulled it off of a 850 Versatile that was using it for the same thing. I was wondering if any one new where to find info on flow and pressure at a rated rpm.
Commercial Intertech by Mid-American Power Drives
Pt. No - 326-9110-169
I've been searching the internet for a couple hours with no luck so if any one could help that would be amazing.
Posted 3/9/2009 22:15 (#637961 - in reply to #637907) Subject: Re: Info for old Commercial Intertech Hydraulic Pump
ND
I seen that website but couldn't find anything on my part number. Might just have to call them or someone else in the morning to see if they have any info on older pump numbers.
Posted 3/9/2009 22:31 (#637994 - in reply to #637961) Subject: Re: Info for old Commercial Intertech Hydraulic Pump
Winkler, Manitoba Canada
I've had the same problem. It seems that the part number often doesn't match with the catalogue number. I thought the identification info on that page might allow you to figure out what you have. Phoning might be your only option though. How do you drive the pump on the cummins? Belt drive from the crank?
Posted 3/9/2009 22:50 (#638043 - in reply to #637994) Subject: Re: Info for old Commercial Intertech Hydraulic Pump
ND
yeah we are going off the crank. It has an electric clutch that looks identical to an A/C electric clutch and we will have to set up the rest of the system on our own, but it's worth a try because it would save alot of money compared to buying the Atom Jet setup.
Posted 3/9/2009 23:14 (#638100 - in reply to #637866) Subject: Re: Info for old Commercial Intertech Hydraulic Pump
Baum Hydraulics carries Commercial Intertech pumps. I see a few part numbers that begin with 391-, but not your number. You could call them at 800-228-9222 and ask.
Posted 3/9/2009 23:20 (#638116 - in reply to #637866) Subject: RE: Info for old Commercial Intertech Hydraulic Pump
Mid-Missouri
Slightly off topic but...We have a 936 and 895. If the time came were our hyd.pump went out or we needed more flow, why can't the original pump be replaced with a larger one. Or, why can't you piggyback a pump inbetween the original? I know some drive one off the crank which also sounds pretty simple. Thanks.
Posted 3/10/2009 15:15 (#638803 - in reply to #637866) Subject: Re: Info for old Commercial Intertech Hydraulic Pump
Germantown, Ohio
It is a C/I 326-9110-169 = P315A189UNAB15-56 CLUTCH PUMP Should have 1.5" gear set which would be 1.7 ci/rev rated to max 3250 psi. Electric clutch and belt will probably never get to that pressure, but the pump will do it.
