| mcinnisfarms - 11/22/2018 11:34
I can stomp on brakes hard and it defiantly affects the steering for just a second. Activating a scv somewhat affects it maybe. One of the codes that popped up is main hydraulic pressure low. Only saw that once. Maybe a pressure sensor? Brakes hitch and scv work fine, hydraulic oil level and filters don’t have a lot of hours on them.
there are 3 sensors in that area that can cause issues. pretty common problem. usually they leak oil though. |
