I looked into those Rectangular lights, for a 4440 conversion and found 2 different "wattage ratings" ; but I never went that direction (bought a light bar instead, for that tractor). I see Larsen lights, has those lights at 20 watts each(55 and 60 series) , and it looks like you would need 3 or 4 total. (EDIT: I see there is a special instruction about 50 series, mentioned on the Larsen lights site = Can be used on the 50 series too, but a new front holder for the lights is needed. JD part numbers :) https://www.larsenlights.com/jd-2-x-5-led-light-20-watt I, also, see Tiger Lights sells some LEDs, for that tractor front hood, at 30 watts, but just barely higher lumens, that Larsen lights. (seems odd, to me such little different, but 10 more watts advertised) https://tigerlights.com/i-23182080-small-rectangular-led-headlight-re306510.html Hopefully, someone has installed EACH product and can help you, on a review.
2nd edit: here's a link to Larsen Lights conversion for 50 series ($249) LED-3000 {obviously, their must be a difference in those older 50 series nose cone parts} https://www.larsenlights.com/led-hood-conversion-kit-tl4000 This must be the kit, from Tiger lights ($380) for a 50 series conversion: https://tigerlights.com/i-23182119-led-hood-conversion-kit-tl4000.html
Edited by 4WD 10/9/2018 14:46
