Gehl silage wagons
Hat creek
Posted 8/5/2018 21:45 (#6913320)
Subject: Gehl silage wagons
I’m looking at a gehl silage wagon. I heard gehl went out of business. Can you still get parts?
redrider806
Posted 8/5/2018 21:56 (#6913352 - in reply to #6913320)
Subject: RE: Gehl silage wagons
wc MN
Around here you can on the later models such as the 970s, older 810s are in doubt
cjd12000
Posted 8/6/2018 05:58 (#6913597 - in reply to #6913320)
candor ny
yes beaters seem to be most replaced large part. they rust from inside out then shear in half. Aprons aftermarket pto's are common so are most bearings you can see. Gearbox might be questionable but never seen one fail.
rockridgefarms
Posted 8/6/2018 06:13 (#6913616 - in reply to #6913597)
sw wisconsin
good dependable boxes, often thought there should be a way to replace the beaters with something else
exdairyguy
Posted 8/6/2018 06:38 (#6913639 - in reply to #6913616)
swmn
I have 2 almost new beaters, and one used one laying here.
cih1660
Posted 8/6/2018 08:08 (#6913829 - in reply to #6913597)
WI
Mine always busted by the hub.
sparrell
Posted 8/6/2018 07:29 (#6913746 - in reply to #6913320)
Hat creek - 8/5/2018 21:45
Beware if it’s got a gehl tandem running gear too...better options out there...
cih1660
Posted 8/6/2018 08:07 (#6913827 - in reply to #6913320)
WI
Like others have said, the beaters on a 970 & 980 are as thick as a coffee can. The 980 beaters will speed up clean out so, it will only take an extra 12 minutes to completely empty a box compared to 20 minutes with the 970 beaters.
nyjim
Posted 8/6/2018 11:17 (#6914168 - in reply to #6913320)
100 miles north of the NYC crapper
I wouldn’t think to would be to difficult for anyone with a little talent to build a new beater if needed.
Big Square
Posted 8/6/2018 22:21 (#6915551 - in reply to #6913320)
Eastern Half of Kansas
1600 series are H&S wagons. I think 1620, 1640, 1660’s
