Middlesex County, Ontario | What is out there for spreading cover crops onto stubble and winter wheat? Everyone in this area uses 12v ATV spreaders, usually a Herd GT77, ourselves included.
The Herd is ok. Its probably the best of all the 12v spreaders on the market. Complaints are that it only holds 40-50lbs of seed. Depending on rate and what we are spreading that could mean 4 acres to a fill. And it sucks backtracking empty, so sometimes you fill every pass (2-3 acres). Other complaints are lack of rate control. Once you have the gate setting and speed worked out it is very accurate, but getting there is tedious.
Is there anything out there with rate control that holds more seed that still fits on an ATV? |
