Whitehouse | Sorry for the delayed response. The mfwd and diff lock solenoid valves are the same. The pto solenoid valve is different unfortunately. With that said, if they are the older type with the square, removable magnet, the magnets are all the same and you would try swapping the diff lock and pto magnets in that case. The fact that it shut down and set a code after messing with the solenoid coil makes me lean heavily towards that coil being the issue. The controller does measure amp draw of the solenoid coil, too high( short) or two low (open), and it shuts off the circuit. Solenoid coil resistance should be 10-12ohms at 20 degrees C.
It is also possible the valve portion has failed in some way, but with the info you have provided I feel that is unlikely. The pto speed sensor could be defective however. In the 20 series, the controller does not monitor circuit continuity for the pto output speed sensor, it only monitors for a speed reading when the pto is switched on. If no speed is indicated within 20 seconds of switching the pto on the controller will switch off the pto. The pto speed sensor is just above or below the pto output shaft, and going by memory should show approximately 550ohms at 20C. Generally they show open circuit if failed.
As far as the fans, check fuses f5-13 and f5-14, both should be 20 amp. Each one supplies one fan with power. The fans share a common ground, through the resistor pack and switch. The positive wire goes directly from the fan to its respective fuse. Lead numbers are 222 and 231.
As far as the speed gears, it may have two, or three solenoids on the front right side of the transmission. Check them and their wiring for any damage, oil in the connector as you said. If there is oil in the connector, the solenoid valve has failed. Resistance should be 15ohms +/- 5 ohms at 20 degrees C.
Also, check the two 80amp fuses up by the battery for any signs of damage, make sure you pull the fuse out of the holder to check. They sometimes will melt or break a terminal off which you cannot see without removing the fuse.
