NE mt | Hey thanks, exactly what I needed! Is there a foolproof way of checking the ecm? I have checked all power and ground pins, most of the sensors, and it still wont go right away, have to sit there for thirty seconds or a lot of times more before the stop engine light goes off and then it sends juice to the fuel solenoid and off she goes, runs perfect until you shut it off again, I sure don't mind getting an ecm but want to be sure that is the problem! Maybe I can send it to cummins and they can bench test? | |
