2009 210 Case IH magnum
gvfarms
Posted 6/6/2018 18:57 (#6798134)
Subject: 2009 210 Case IH magnum
northwest ohio
Stop to get out of the tractor. Put it in park get back in and the shift lever will come out of park and go to the neutral position but the lever will not go to forward or reverse. Didnt throw any codes. Check 30 amp FNR fuse behind the seat and its good. Anyone have any ideas ? Will call the service manager in the morning. TIA
Jim Naden
Posted 6/6/2018 19:52 (#6798208 - in reply to #6798134)
Subject: RE: 2009 210 Case IH magnum
Southeastern Tipton County, Indiana
gvfarms - 6/6/2018 19:57 Stop to get out of the tractor. Put it in park get back in and the shift lever will come out of park and go to the neutral position but the lever will not go to forward or reverse. Didnt throw any codes. Check 30 amp FNR fuse behind the seat and its good. Anyone have any ideas ? Will call the service manager in the morning. TIA
The lever won't physically move from the center into either reverse or forward?
gvfarms
Posted 6/6/2018 19:56 (#6798219 - in reply to #6798208)
northwest ohio
Jim, correct the lever will not physically go in forward or reverse
CASE3594
Posted 6/6/2018 22:34 (#6798593 - in reply to #6798219)
Tuscola, IL
I’d say you have a mechanical problem with the shift lever itself. To my knowledge, there is nothing in the assembly that prevents it from moving. Likely something has come apart or broken within the lever assembly.
outsidethebox
Posted 6/6/2018 20:10 (#6798253 - in reply to #6798134)
Memphis, NY
Same thing happens if batteries go dead. I couldn't begin to guess why your computer hiccupped, but the procedure to get it out of park is in the 4- section of the manual (4-12? Maybe?). Something like hold the brakes, hold the neutral button, and remove from park position.
redblooded
Posted 6/6/2018 20:25 (#6798299 - in reply to #6798134)
Shelburne Ontario Canada
Grab hold with 2 hands and mske it go! They bind up inside. Time to take apart an gresseit.
SDman
Posted 6/7/2018 07:22 (#6798875 - in reply to #6798134)
Needs a FNRP lever assy. Pretty common repair. Sometimes you can lube them up to last a little longer, but it’s only a temporary fix. The other problem with that lever is that the neutral button will stick, causing fault code 2387. The new lever assy. will have a different neutral button setup on it as well. Good luck!
gvfarms
Posted 6/7/2018 11:04 (#6799219 - in reply to #6798875)
northwest ohio
thanks for replies, Needs a new lever assembly. Dealer just replaced one yesterday on another magnum
SDman
Posted 6/7/2018 13:13 (#6799360 - in reply to #6799219)
Yup, happens on the smallest of Maxxums all the way through the biggest of Steigers and everything in between. The newer handle does seem to work better.
RBM88
Posted 6/7/2018 07:22 (#6798876 - in reply to #6798134)
just happened to our 180 spring broke in the handle need a new controller
