Search Forums | Classifieds (122) | Skins | Language
New Holland 8870 detent problems
dlfarms1984
Posted 5/19/2018 10:00 (#6767839)
Subject: New Holland 8870 detent problems
wc Ohio
I have remote number 3 on my planter lift. The detent is working just fine but sometimes when it snaps back to neutral the pump will still be stroked until I move the lever slightly back and forth. It's like it is sticking slightly. I took the dent cap off and things look good under there as far as the springs. There was some oil came out when I took the cap off which alarmed me but I think it may have came from the small holes going to the detent adjustment screw. This stack was just completely gone through by a local dealer and all orings replaced.
Also does anyone know how many detent balls should be in each remote? Thanks.
Bern
Posted 5/19/2018 11:30 (#6767961 - in reply to #6767839)
Subject: RE: New Holland 8870 detent problems
Mount Vernon, WA
There should be no oil in the detent housing. This indicates a leak inside, and will definitely restrict spool movement if you get too much oil in there. Did the problem go away after you drained the housing and put it back on?
dlfarms1984
Posted 5/19/2018 11:34 (#6767964 - in reply to #6767961)
wc Ohio
I have not put it back together yet.
Bern
Posted 5/19/2018 11:35 (#6767965 - in reply to #6767964)
Mount Vernon, WA
Try it. If the problem goes away, you've found the issue. You need new seals on the detent release piston.
dlfarms1984
Posted 5/19/2018 11:41 (#6767974 - in reply to #6767965)
wc Ohio
Ok good idea, do you know how many detent balls should be in there? I have 8.
Bern
Posted 5/19/2018 11:47 (#6767981 - in reply to #6767974)
Mount Vernon, WA
Parts book calls for 8, ref #19 here: https://partstore.agriculture.newholland.com/us/parts-search.html#ep...
Edited by Bern 5/19/2018 11:48
dlfarms1984
Posted 5/19/2018 11:56 (#6767999 - in reply to #6767981)
wc Ohio
Thanks Bern. I feel like these hydraulics are going to be a constant pain but I hope I'm wrong.
blackfarmer2
Posted 5/19/2018 13:55 (#6768165 - in reply to #6767999)
dlfarms1984 - 5/19/2018 12:56
my experience on 8770 yes!
Fawazhay
Posted 5/19/2018 21:34 (#6768812 - in reply to #6768165)
Northern CA
My experience is when an issue starts back there on the hydraulic stack, completely rebuild all of it, detents, female couples, o rings, etc. My problems went away once I did it all.
