Nebraska, The land of corn and cattle | Check the fuel cap, have you replaced it recently? Many of the non vented caps get mixed up with the vented caps. The vented ones are for the single tanks.
The non vented went on the main tank under the hood, and then a vented cap on each of the fender tanks, if you have them.
Sounds like a fuel system issue, I would check for obstructions like a bug in the lines or the sediment bowl, could be in the tank too. Is it fairly consistant on run time or does it seem to vary? |
