Posted 3/29/2018 08:51 (#6672606) Subject: Crankcase filter.......Case IH
Have a 250 magnum. Book says change the filter at 1200 hours. Had a mechanic thought they changed them at 600 hours. What have you guys done on this? Anyone change it before 1200 hours? Book also says change engine oil at 600 hours...we change it about every 150-200 hours or twice a year.
Posted 3/29/2018 10:04 (#6672757 - in reply to #6672683) Subject: RE: Crankcase filter.......Case IH
South central MN
I'd change it every 600 hrs myself. I've seen one with right around 900 hrs fail and send filter material down into the crankcase causing some issues. Do NOT drop the bolts when changing that filter, you will be sorry.
Posted 3/29/2018 11:24 (#6672993 - in reply to #6672757) Subject: You tube video ???
Central Illinois
Are there any videos showing this procedure? Planned on doing a Magnum 235 and a T9-390 next week . So where do the bolts go if you drop them ? Fall into the front cover or just lost in the frams rails? Probably should not be done by a senior citizen that can;t hardly grip a fork ?
Posted 3/29/2018 12:53 (#6673229 - in reply to #6672993) Subject: RE: You tube video ???
South central MN
I'm not aware of any videos Steve. This picture is a 12.9 Iveco from a 550 Steiger and the filter bolts to the gear at 3:00, Magnums are a little different but same location and bolts go to the same place if you drop them, right into the geartrain. I stuff rags as best as I can just in case. I suggest a magnetic socket and/or steady hands.
Posted 3/8/2020 14:45 (#8089546 - in reply to #6673229) Subject: RE: dropped bolt
any advice for finding a beather bolt once dropped inside the gear case? 4430 sprayer dropped the third bolt inside, i have pulled the oil pan, flushed diesel down from the top of the gear case and tried blowing it out with the air hose. i can turn the engine over with a wrench its not stuck in a gear
Posted 3/8/2020 16:04 (#8089664 - in reply to #6672606) Subject: RE: Crankcase filter.......Case IH
A corn field somewhere on planet vulcan
I also change with every oil change. How about just taking all of the filter material out and putting the frame of the filter back in or even take the filter out and leave it out and call it good?
