Search Forums | Classifieds (35) | Skins | Language
looking for oil specs on a Hyster H50XL forklift
Huib Z
Posted 2/25/2018 17:00 (#6604629)
Subject: looking for oil specs on a Hyster H50XL forklift
Dresden, Ontario
would anybody on here have some info on what type of hydraulic oil and transmission oil to use in a Hyster H50XL forklift, it was built in the 1988 and unfortunately we do not have a service/operating manual for this unit.
Any info would be greatly appreciated.
1586
Posted 2/25/2018 17:58 (#6604745 - in reply to #6604629)
Subject: RE: looking for oil specs on a Hyster H50XL forklift
I run hyguard in them. The H50 has a filter that clamps inline. Might be a good time to change it. They are a Mazda engine. Engines take 10-30 oil.
jdillfarms
Posted 2/25/2018 21:23 (#6605341 - in reply to #6604629)
NE OK
It's j-20c, so hygard is fine.
Huib Z
Posted 2/25/2018 22:18 (#6605427 - in reply to #6605341)
Dresden, Ontario
Thanks a lot guys! that was some helpful info, I couldn't remember for the life of me what we changed it with before.
Have all the filters here including the clamped inline.
you guys use hygard for the transmission as well?
1586
Posted 2/26/2018 07:16 (#6605671 - in reply to #6605427)
Yes had a H35 and have a H90 also a JD 482C and had a few others in between all take Hyguard. It's fine for the F/R clutch.
Huib Z
Posted 2/26/2018 11:22 (#6606175 - in reply to #6605671)
Dresden, Ontario
thanks for your help!, got it figured out and done, I now remember how it is a bit of a pain to work on them too....ha ha
jmiller
Posted 2/27/2018 20:55 (#6609310 - in reply to #6604629)
West central Ohio
We have a H50XL also. Book and service guy says AW32 (or ISO 32) hydraulic oil. Service guy said do not use regular HyGard. It is too heavy. Regular HyGard is between AW 46 and AW 68 in viscosity. Lo-vis HyGard meets AW32 specs (about 10w). He uses AW32 hydraulic oil from O'Reilly's in all the lifts he services. Has several hundred under service contract.
Linda Christina
Posted 9/26/2018 00:09 (#7009412 - in reply to #6604629)
In that forklift you can use one fluid for both hydraulic oil and transmission, we’d recommend Mobilfluid 424 which meets JDM J20C specification.
http://store.intellaliftparts.com/blog/hyster-forklift-fluid-specs/
