Search Forums | Classifieds (64) | Skins | Language
Anyone have experience with PETLAS tires?
Pofarmer
Posted 1/29/2018 18:46 (#6540546)
Subject: Anyone have experience with PETLAS tires?
The price is great, but I'm a little skeptical.  These are on a tractor that will probably get 250 hrs per year and not a ton of road miles.
exdairyguy
Posted 1/29/2018 18:52 (#6540571 - in reply to #6540546)
Subject: RE: Anyone have experience with PETLAS tires?
Swmn
Run and run fast don't look back
GoodOldDeeres
Posted 1/29/2018 18:55 (#6540576 - in reply to #6540546)
York, Ontario
We don't buy anything but Petlas. Far cheaper, but heaver, deeper lugs last longer than many of the big brands. We've got them on the combine, 4wd and 2wds...on road, off road they are excellent.
Gearclash
Posted 1/29/2018 19:07 (#6540624 - in reply to #6540546)
Sioux County, NWIA
My tire guy says they are junk. But I did put a set of new take off Petlas 460R-38s on a tractor this spring just prior to selling it. They rode nicer than the radials they replaced.
PTS
Posted 1/29/2018 19:12 (#6540641 - in reply to #6540546)
I have two sets and have been better than my Firestones
N.of nowhere
Posted 1/29/2018 19:41 (#6540734 - in reply to #6540641)
Ontario
Junk..lugs are good for wear but side walls will be shot when tires are at wore down to 70%.. bkt are twice the tire if your looking for cheap...
Pofarmer
Posted 1/29/2018 19:42 (#6540739 - in reply to #6540734)
BKT is certainly in the running.  If I could get local dealer to a grand per tire they would probably be my pick.
GoodOldDeeres
Posted 1/29/2018 20:00 (#6540784 - in reply to #6540739)
York, Ontario
Counting them up we've bought 22 Petlas tires with no issues...however although they are radials we don't run real low air pressure in our tires...maybe others have and its caused side wall issues?
Pofarmer
Posted 1/30/2018 08:17 (#6541696 - in reply to #6540784)
That's what I'm wondering as well.  All of the radials we have we run pretty standard pressures in them.  I don't like broken tires. How long have you had your oldest set?
Edited by Pofarmer 1/30/2018 08:17
Dekalb
Posted 1/29/2018 20:05 (#6540798 - in reply to #6540546)
JUNK!!! You get what you pay for. Sidewalls crack on them
bkandra
Posted 1/29/2018 20:12 (#6540821 - in reply to #6540798)
We needed new tires on a 8320 a few years ago when prices were high. Petlas was about 1/2 price of Firestones at that time so decided to give them a try. Currently have about 2200 hours on them. The only complaint so far is they outside tires seem to have a fair bit of stubble checking at the lugs. This is from wheat straw. Everyone likes Michelin, but you could give me a set. The last three sets I had on various tractors didn't make it to 2500 hours before the sidewalls gave out. Michelins are what these Petlas's replaced.
H&T
Posted 1/29/2018 20:35 (#6540898 - in reply to #6540546)
NE Iowa
I have a pair of 14.9X28 on FWA that pulls planter in notill corn stalks and I had no issues, would buy again
farmerkirk
Posted 1/29/2018 21:22 (#6541045 - in reply to #6540898)
SC Kansas
Some on loader, haying tractor. Seems some manure, some roading. They have a 1k+ hrs them. No cracks, great wear, good ride. I'm impressed.
Also it's FWA, there isn't a noticable difference in the wear on the fronts vs rear tire.
Edited by farmerkirk 1/29/2018 21:26
Avg. Joe
Posted 1/29/2018 21:33 (#6541090 - in reply to #6540546)
Elmwood, Ne. Just East of Lincoln
I put a set on a Killbross 550 bu grain cart over 10 years ago. I was impressed for the money. Sold it to a neighbor and as far as I know they are still going strong.
redblooded
Posted 1/29/2018 21:48 (#6541138 - in reply to #6540546)
Shelburne Ontario Canada
Put a set on dad 80 hp loader. Likely 3 -4 yrs ago. They were cheap an we went size wider an still cheap. We run around 20 - 25 psi in fronts think they are 320 something 24s. Wen we lift a seed tote they are flat on the rim but it only does wen i a pinch to load seeder. Round haylage they squat a bit. Tractor got 350hrs last yr so guessing well over 1000 hrs tractor rarely leaves the concrete yard . Fronts are starting to show ware but back are almost new. Have hear all sorts of wild storys about guys ripping lugs out an side walls giving out but if the front take it on this tractor then they obviously arent complete crap. We tend to run mostly BKTs on anything that needs retired. But last tractor we slipped to Galaxys for 710/70/r38 4 yr feild hazard warranty sounds exciting.
m3farmer
Posted 1/30/2018 01:30 (#6541346 - in reply to #6540546)
SW Minnesota, Lyon County
Didn't read all responses, figured some best thing since sliced bread to absolutely junk. I can only give my personal experience. Needed some tires for an M3 combine. Supplier had some Petlas (only in five state area). Put them on and ran them for 2 years on 600 acres each year. I was absolutely ecstacic about how they performed. They could very well have fallen apart the next couple of years.
Adam Suess
Posted 1/30/2018 09:47 (#6541899 - in reply to #6540546)
Hanska, Minnesota
I have 8 20.8-38/520-38 on a small 4wd about 6 years ago love the traction and there wearing extreamly well but the side walls are cracking bad. Some do not hold air very long any more. I put there version of 18.4-38 on a MFWD Oliver. Turns out there tire is much smaller and it caused problems with my MFWD ratio. I traded them back in for Mitas tires which corrected the problem. Mitas on the right Petlas on the left. Photo of cracking tire was 2 years old at the time.
Edited by Adam Suess 1/30/2018 10:18
(0426161547.jpg)
(0311161519 - Copy - Copy.jpg)
(0328161814a.jpg)
Attachments 0426161547.jpg (126KB - 282 downloads)
Attachments 0311161519 - Copy - Copy.jpg (99KB - 267 downloads)
Attachments 0328161814a.jpg (130KB - 262 downloads)
