nebraska | I skinned the blade on my D6R series 2,,. I went to a welding shop that had some AR steel that they also have a roller, so I had a template made with cardboard that matched the curve of the blade, they rolled it to almost the curvature,
I then cleaned the front of the blade up, welded a couple tabs along the bottom to align where I wanted the plates to sit, I then wrapped a 1/2" chain around the blade vertically, I took my porta power with the v attachment on one end of the cylinder( chain side) and the flat plate on the other end, put it under the chain and pressed the final curve out of the skin and welded the plate into place,, I installed the plate in 2 pieces( left half, right half), that way you can weld the middle also and wasn't so hard to press into place and fit closer,, it took the better part of a day once I had the steel in hand,,,.
The steel cost was around $ 700 if I remember correctly along with the cost of them rolling and shearing it to size,, | |
