Search Forums | Classifieds (118) | Skins | Language
case 4890 transmision problems
goosebay farm
Posted 12/10/2017 13:38 (#6419274)
Subject: case 4890 transmision problems
Hi all
Can some 1 help me plz,i am from SA and i have a problem with my case 4890.
I removed the valve bank and cleaned all valves and all is working 100%
When i pres the clutch to deep while driving it stops completly as iff the brakes are used and when i reverse its also as iff the brakes is on,can it be that the case stays in 4x4 mode or what
croptecsolutions
Posted 12/10/2017 13:52 (#6419304 - in reply to #6419274)
Subject: RE: case 4890 transmision problems
ok
Does it pull good in all powershift ranges? Almost always the problem you describe is a sticking valve spool
goosebay farm
Posted 12/10/2017 14:09 (#6419335 - in reply to #6419304)
Yes it takes all the gears and lots of power.i changed the planetery gears the old ones broke it made a noise and after there where now gears and when i replaced it i started having this problem.i am sure there are no sticky valves
goosebay farm
Posted 12/10/2017 14:22 (#6419358 - in reply to #6419335)
While the case is running in neutral i can put it in all 3 power shift gears but when i put it in reverce the engin cuts off.It can reverce when i put the case in 4th gear and high reves but its as iff the hand brake is on
Attachments (0KB - 47 downloads)
Attachments (0KB - 42 downloads)
goosebay farm
Posted 12/10/2017 14:23 (#6419362 - in reply to #6419335)
WisTreemover
Posted 12/10/2017 14:42 (#6419395 - in reply to #6419274)
East Central wisconsin
Did you adjust the retard screws in the valve cover? Does the eng labor slightly when powershifting from 1st to 2nd? And then back down 2nd to 1st. If it labors to much. Those two screws are in too tight. If this doesnt help? And no spools are sticking? Sounds like something internal didnt go together properly ??? Good luck.
goosebay farm
Posted 12/10/2017 14:48 (#6419403 - in reply to #6419395)
Hi.Yes it labor a lot when i shift it to 1 and 2.where are those 2 screws is it on top of the valve cover or inside and could that be the reson why the reverce is so hard to back up
WisTreemover
Posted 12/10/2017 14:58 (#6419425 - in reply to #6419403)
The two screws that adjust the flow of oil leaving the clutch packs. Are on the face of the powershift valve. If memory is correct? It takes a 7/16" wrench to loosen jam nut. Then a flat bladed screw driver to back them out slightly. The upper one towards front of tractor adusts up shift from 1 to 2. The bottom one adjusts down shift from 2nd back to first. Oil should be at operating temperature to get best results. Transmission should be in neutral while adjusting. Also tractor shouldnt go in reverse in 4th gear. Wondering if reverse lockout spool is in backwards?
goosebay farm
Posted 12/10/2017 15:13 (#6419452 - in reply to #6419425)
Whitch spool is reverce c1 c2 c3 c4? Sorry but i am lost with this.
WisTreemover
Posted 12/10/2017 15:22 (#6419467 - in reply to #6419452)
Did the tractor go into reverse in 4th gear before you worked on it ?
The reverse lock out spool is the one off the side of the valve. The other spools are on the top or bottom of the valve.
goosebay farm
Posted 12/10/2017 15:26 (#6419474 - in reply to #6419467)
Yes it reversed in all 4 gears.when i put the gear any gear and the right hand side gear in reverce it did reverce but made a noise.should i leave the normal gear in neatral and only put the power shifter in reverce?
WisTreemover
Posted 12/10/2017 15:38 (#6419494 - in reply to #6419474)
Maybe I'm remembering it wrong? But I didnt think the shift linkage would allow the powershift to go into reverse, if the transmission was in 4th gear?
But the tractor does labor some when shifting into reverse.
Good luck.
goosebay farm
Posted 12/10/2017 15:50 (#6419521 - in reply to #6419494)
Thanks for your help and time in SA its 23:48pm tomorow ill try and get that baby to work 100% i am al ready late for planting maize but i am sure the case will make it.
Thanx
Robert
goosebay farm
Posted 12/10/2017 15:34 (#6419490 - in reply to #6419467)
The flat side of the spool is on the oud side of the valve and the point side is inside the spring is pushing from the oud side on the vlad side of the spool
WisTreemover
Posted 12/10/2017 15:41 (#6419501 - in reply to #6419490)
That sounds correct. Should be ok.
