Between Omaha and Des Moines, 7 miles South of I80 | I think you should consider a outer trench, for rodent control, just as m3farmer mentioned on his bin foundation. My brother built bin foundations and did bin repairs, for 8 years and they all got outer trenches, on outer perimeters using a Ditch Witch trencher ( I think it went 28" deep). [Later, he went to strictly building new bins.] He always said: Once you have to lift a bin and bust out the older flat concrete slabs, that were too weak and cracked/buckled and had varmints tunneling underneath, you will talk the farmers into using "rodent control" for their next slab. {Busting out concrete is a miserable job, I assume} On the trencher, he had big center stake, with a pivot ring, then a chain assembly that hooked onto the trencher in two locations, so it pulled evenly around in a circle. |
