Can anyone tell me about a Landoll planter (4400). Will they plant No-Till, are parts available, The good and bad, nice unit for sale but just don't see many. Thanks.
Posted 4/27/2017 07:11 (#5984882 - in reply to #5984716) Subject: RE: Landoll Planter
northeastern Ohio
I've never seen one before, so I had to look. Interesting setup!
Advantages: They use 16" offset openers (good for no-till) and then use 18" closing discs right behind (should also work for no-till). Looks like they used a vacuum system for the seed metering.
The disadvantages I see: it looks like the gauge wheels are connected to the closing discs which means the depth control is behind the openers and therefore your seed depth might vary in uneven conditions. Landoll always builds their equipment heavy, so that might be a disadvantage in soft conditions.
