Search Forums | Classifieds (68) | Skins | Language
Value of tile for depreciation
MN Wally
Posted 3/2/2017 09:55 (#5873095)
Subject: Value of tile for depreciation
SE Minnesota
How do you put a value on existing drainage tile for depreciation when you buy or inherit a farm? If it is 10 or 20 or 50 years old.
Cattle Feeder
Posted 3/2/2017 10:26 (#5873149 - in reply to #5873095)
Subject: RE: Value of tile for depreciation
$900 an ac.. If they question it,, toss them a shovel.. It doesn't wear out so use NEW value..
boog
Posted 3/2/2017 10:45 (#5873200 - in reply to #5873149)
Evidently you've never been around concrete tile. We've replaced a lot of deterioraed concrete tile that was put in back in the '50s & '60s. Also, if they (IRS)questions it, you'll be the one that will have to prove it, not them.
jakescia
Posted 3/2/2017 12:58 (#5873500 - in reply to #5873149)
Subject: If it "...does not wear out...", then no depreciation is allowable.......
Oskaloosa, Iowa 52577
Iowaluck
Posted 3/2/2017 23:10 (#5874784 - in reply to #5873149)
NC Iowa
My tax man uses 10 percent of purchase price. Not sure what is right but the IRS accepts that method, so I run with that.
Dave NWIL
Posted 3/2/2017 10:39 (#5873178 - in reply to #5873095)
There's no right answer. It's a judgement call. Generally 30 t0 50% of new depending on age and condition.
Hopefully you have some tile maps to estimate the feet and size of existing tile.
MN Wally
Posted 3/2/2017 10:45 (#5873201 - in reply to #5873095)
SE Minnesota
Thanks for the replies,I do have maps with feet, size and age. It is all working good, 95% plastic,most of it installed since 1999.
boog
Posted 3/2/2017 10:50 (#5873210 - in reply to #5873201)
That helps a lot. I would suggest meeting with your accountant to determine a depriciation schedule that will reflect an accurate value to the tile.
Dave NWIL
Posted 3/2/2017 11:26 (#5873308 - in reply to #5873201)
That helps. That new and plastic I might be inclined to go higher than 50%. Yes discuss it with your accountant.
jakescia
Posted 3/2/2017 12:57 (#5873494 - in reply to #5873308)
Subject: Pigs get fatter, hogs go to market. 50% is pretty good, when age is not known.
50% is pretty good, when age, size, and usability is not known.
Remember......tile is deemed to be a land improvement.......and NOT depreciable.
Therefore, IRS deems it to be ongoing value, just like land, and therefore with no obvious terminal life........there is no obvious end of life, and no depreciation.
However........just because of a rule that was established in the old investment credit days.........land improvements (such as tiling and fencing) are DEEMED to be depreciable property, if involved directly in the act of production.
So........since tiling becomes depreciable just because of an old rule.......don't get greedy.........and have the result being the IRS requiring you to PROVE the existence of tile, its value, and its usability.
Make sure you have documentation.......that it is logical........and that you can show how you have established the existence, the value, and condition of land improvements that you want to depreciate.
cho
Posted 3/2/2017 13:03 (#5873510 - in reply to #5873494)
Subject: RE: Pigs get fatter, hogs go to market. 50% is pretty good, when age is not known.
How many years would you say for new tile?
jakescia
Posted 3/2/2017 16:17 (#5873880 - in reply to #5873510)
Subject: New tile--- has MACRS class of 15, MACRS ADS life is 20.
Fencing is a land improvement, that gets its depreciable nature under the same rule as tiling........but it has a class life of 7 years.
paul the original
Posted 3/2/2017 17:12 (#5873958 - in reply to #5873880)
Subject: RE: New tile--- has MACRS class of 15, MACRS ADS life is 20.
southern MN
Wow, 7 years for fence! I believe some posts are still standing that grandpa and dad put in, with the same wire stapled to it. Granted that needs to be replaced, should have been a couple years ago, but - I never knew my grandpa, that fence been keeping cattle in (mostly) for over half a century and then some.
Good conversation on the ramifications of all this tax finagling. Lot of details to keep straight for long periods of time on this one. As always, one can postpone some tax, can't really run away from it entirely.
Paul
CRJ
Posted 3/2/2017 18:24 (#5874089 - in reply to #5873510)
NEIN
Section 179 it, all in one year.
paul the original
Posted 3/2/2017 13:12 (#5873533 - in reply to #5873494)
southern MN
I have aerial photos of dry streaks in the property I bought, and a pic of the fence on one side of it with my cattle grazing corn stalks nearby showing I do use fencing out in the fields.
My accountant took my new cost install numbers with my footage calculations and applied 50%. That seems reasonable to me.
He's a good CPA that does lots of farm accounts, actually he reminds me a lot of you Jake from the little I know of each of you. He has a passion for his work that shines through, I think he could easily retire - he has done every one of my tax returns, he's been at this a while - but I think he would rather work his calculator than sit in retirement.....
Paul
roarintiger1
Posted 3/2/2017 13:47 (#5873611 - in reply to #5873533)
NW Ohio
Just remember if you buy a farm and then determine an amount to depreciate the tile, you must also lower the basis you have in the farmland. Example would be if you bought a farm for $500,000 and depreciated $50,000 worth of tile, your new basis for when you sell the farm would be $450,000.
Is this correct Jakescia?
Edited by roarintiger1 3/2/2017 13:48
boog
Posted 3/2/2017 15:27 (#5873784 - in reply to #5873611)
I'm not an accountant but that would seem logical. But, the gov seldom uses logic ÷:))
jakescia
Posted 3/2/2017 15:55 (#5873832 - in reply to #5873611)
You are correct.
If whole farm costs 500,000......and you can justify that there is 50,000 worth of tile on that farm when purchased,
you would allocate 450,000 to farm land......and 50K to depreciable tile (if you are a producer).......
Upon sale..........you would have 450K in basis in land.........and whatever, if any, unadjusted basis left in the tile........ie tiling like other depreciable assets do not have to be written off under section 179..........so if there were 30K of un-depreciated basis left.........the entire basis would total 450+30 = 480000.
AND-------- the sales price should be allocated between the land, and the tile.
The land would be asset sold at tax rate of 15% (assuming long term capital asset),
but the tile would be sold as section 1245 asset.......same as sale of tractor.......and the depreciation would be recaptured in year of sale to the lower of sales price or depr taken.
NOTE......... if the tile portion is significant.........and if the 1245 gain would be significant...........and if the land were being sold on the installment basis..........then remember that the 1245 gain is recaptured in year of sale regardless of the amount of cash received for that portion of the entire sale.
Therefore, it would be prudent to say in the contract that the FIRST cash received would go towards the tile portion of the sale.  In the absence of agreement to contrary, IRS has the right to allocate on a "fair basis"........and that logically would be same percent of gross sales of the portions, times the cash received...........which would obviously be adverse to the taxpayer.
Lastly.........the IRS has the right to check how the buyer handled the sales transaction as compared to the seller.
So.......if seller allocated nothing to the tile portion of the sale, and the buyer allocated a big bunch.........and the IRS was chasing one or the other taxpayers.........either could get tripped up.
So.......be alert to be reasonable.........but the best route is an allocation in the contract.........which is seldom seen, merely since it is an element that causes big-time friction.
Just be aware that there are other reasons for being reasonable, and documenting one's position to extent possible.
roarintiger1
Posted 3/3/2017 07:49 (#5875192 - in reply to #5873832)
NW Ohio
jakescia - 3/2/2017 15:55
You are correct.
Thank you Jake!
So.........let's say you have been reasonable in allotting a value on the tile, but the seller has allotted nothing. Who gets the IRS visit? I would almost be certain that the buyer and the seller never get together. If they treat the sale the same, it would be just a coincidence. :)
jakescia
Posted 3/3/2017 09:29 (#5875426 - in reply to #5875192)
Subject: Likely the seller will say none, or very little, and buyer large amount.
If I were preparing for either.....
.... I would have aerial photographs if such show the lines.....or don't show the lines.
If seller, I would have prior year tax returns showing tile purchased/not purchased, and if purchased, would have invoices and affidavits from anyone involved in installation as to where installation occurred.
If buyer....
...aerial maps,
pictures of tile outlets, stand-pipes, etc.
maps showing layout (since then IRS could choose any spot along those lines and ask for a digging),
topographic maps showing lay of land, and how that ties to tile outlets and logical placement of tile lines.
Always remember.......as crappy as it is.........IRS has the right under statute to argue out of both sides of its mouth....
.....it could argue against the seller that tons of tile was out there--------- which, if the seller was being honest, and did his homework by showing the location of tile that he had previously included and depreciated in his prior tax returns, the seller would easily refute.......and IRS would not pursue that.
The seller has the advantage (or maybe disadvantage, depending on the stance he took) of being able to use prior tax returns as evidence.
NOTE also that it is REMOTELY POSSIBLE.......depending upon the circumstances..........that if seller installed tile years before, but did NOT take any or just nominal depr on it, that such undepreciated basis in that old tile would add to the basis of the overall land.........and hence helping seller's position.
The buyer would be the one that is typically cooked.........in the absence of tile maps drawn and signed by the seller.........the buyer is at the mercy of no documentation........and therefore would have to be real creative and detailed, in order to build a case that would be believable by a court.
That is why I emphasize that especially buyers need to be just "pigs"........and do a detailed job of documentation..........and I would, if I had to choose just one item, choose a tile map drawn on a topo map.
Take pictures of stand-pipes and outlets.........and then tie all of that together in the maps showing how the area could be drained to those outlets.
Is it worth it?
Well..........say it takes a full three days = 24 hours.
Say.........50,000 of tile dollars........ x 15% income tax and 15% self employment tax.......and 6% state tax. = 36% x 50K = 18,000 taxes.
18,000 taxes / 24 hours = 750 per hour effective wages.
Or, say one spends an entire week....... 40 hours....... = 450.00 per hour wages.
Seems to me to be worth the trip........especially since the money was already spent for the tile/land.
Edited by jakescia 3/3/2017 09:32
redoak
Posted 3/2/2017 16:42 (#5873922 - in reply to #5873095)
deep SW On.
Maybe a "here" thing but tile when installed is a 100% deduction....on bill of sale or some place you would need too have a "value" placed on tile or buildings to depreciate it and seller/estate would then have too claim that value as capital gains as they have already depreciated it once
