Search Forums | Classifieds (129) | Skins | Language
Grasshopper Hydro oil
[email protected]
Posted 2/28/2017 12:36 (#5868729)
Subject: Grasshopper Hydro oil
Titonka, IA
Do any of you use a different hydro oil than what Grasshopper sells? ($20 some/ qt) If so, what do you use?
Edited by [email protected] 2/28/2017 12:37
midnight
Posted 2/28/2017 12:43 (#5868750 - in reply to #5868729)
Subject: RE: Grasshopper Hydro oil
Minn
I would like to know also
milofarmer
Posted 2/28/2017 13:16 (#5868800 - in reply to #5868729)
I just bought a quart from my grasshopper dealer the other day. Parts man claimed it is 15w50 synthetic mobile. I can't verify, but that's what I was told.
TP from Central PA
Posted 2/28/2017 18:32 (#5869318 - in reply to #5868800)
That is what I run in them. 20W50 also works but the 15 is better when used for snow removal on grasshoppers, most other makes aren't run in the winter.
Valley Farmer
Posted 2/28/2017 20:56 (#5869726 - in reply to #5869318)
SC Kansas
We have an older gentleman here who used to work at the grasshopper mfg plant. He now has his own shop to work on them. He told me it is mobile synthetic i think 15-40 not real sure on the viscosity.
jalopy
Posted 2/28/2017 13:24 (#5868814 - in reply to #5868729)
NC IA
Interested in replies.
I need to change mine also, I've been threatening to use CIH Hy-Tran. Ask most any hydraulic rebuild shop and the consensus is Hy-Tran is the best hydrostatic oil ever made, and no they don't sell it or get paid to say that. And since its been improved to withstand 7000+ psi in CVT's, surely it would work fine in a stupid lawnmower.
Buster 50
Posted 2/28/2017 14:52 (#5868942 - in reply to #5868729)
North West IA/western AZ
[email protected] - 2/28/2017 11:36
Is this for a 600 series or a 700 series? They call for different oils. The 700's will take the same hydraulic oil you use in a tractor or combine.
dondozer
Posted 2/28/2017 16:07 (#5869058 - in reply to #5868942)
NW Ohio,near Findlay
watching replies also, grasshopper oil too expensive.
boog
Posted 2/28/2017 17:40 (#5869230 - in reply to #5868942)
What about the 900 series Grasshoppers? We have a 935D. I have always used Grasshopper's hydro fluid. It seems high priced but no more than it takes & no more often than it needs to be changed I never thought that much about it.
RickB
Posted 2/28/2017 16:49 (#5869127 - in reply to #5868729)
Lincoln County. NC
Find out what transaxle is in it and poke around. 20W-50 motor oil is popular, as is 0W-40. The guy that chases parts for our shop got some Mobil hydraulic oil for older Woods machines built by Grasshopper because we couldn't stand the price of the Woods oil.
Edited by RickB 2/28/2017 16:51
TractorAddict
Posted 2/28/2017 17:20 (#5869196 - in reply to #5868729)
West of Broken Bow
Just recently saw an Amsoil advertisement for it.
http://www.amsoil.com/shop/by-product/hydraulic-oil/synthetic-tract...
http://www.nextechclassifieds.com/listings/1200155/
http://www.syntheticsofcolby.myamsoil.com/
Grasshopper Mower owners, don't pay 15 dollars a quart for your Hydrostat Oil every 1,000 hours!! We have in stock the AMSOIL Full Synthetic Oil perfect for your machine at almost half the cost!!
Excellent Protection in Temperature Extremes
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil operates over a wide range of temperatures. It has a high viscosity index to maintain its lubricity for wear protection at high operating temperatures, and it flows at temperatures down to -58°F (-50°C) for improved equipment operation at low temperatures. Synthetic Tractor Hydraulic/Transmission Oil replaces both Case New Holland 3525 and 3526 (formerly FordNew Holland FNHA-2-C-200 & 2-C-201) and John Deere J20C & J20D, helping eliminate the need for seasonal oil changes.
Smooth Brake Operation
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is formulated with durable friction-modifier additives that effectively suppress wet-brake chatter. Unlike lower-quality oils that can break down and cause vibration, AMSOIL Synthetic Tractor Hydraulic/Transmission Oil provides continuous frictional stability for long-term smooth brake operation.
An SAE 5W-30 Fluid Formulated for All-Weather
Performance in Farm and Commercial Equipment
DATA BULLETIN
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is an all-weather Universal Tractor Transmission Oil (UTTO) engineered to meet the tough demands of heavy-duty, hydraulic-powered farm and commercial equipment. Its unique formulation of synthetic base stocks and additives effectively reduces wear, resists heat, protects against rust and extends fluid and equipment service life. Synthetic Tractor Hydraulic/Transmission Oil is recommended for extended oil drains based on oil analysis.
APPLICATIONS
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is recom-
mended for equipment combinations of transmissions, hydraulic
systems, final drives, power take-off systems and wet brakes
operating in “all-weather” hot and cold temperatures, includ-
ing, but not limited to, those listed below. Consult your owner’s
manual for specific application requirements:•
Farm tractors and equipment•
Fork lift trucks•
Off-road equipment•
Lawn tractor hydrostatic transmissions•
Golf course mower hydrostatic systems•
Some 4x4 ATV models with wet-brake differentials
SPECIFICATIONS
AMSOIL Hydraulic/Transmission Oil is recommended for trans-
mission and hydraulic applications that require any of the listed
specifications. Consult your owner’s manual for specific applica-tion requirements.•
AGCO/Deutz-Allis/Allis-Chalmers
– PowerFluid PF-821 XL, 25741,246634•
AGCO White Farm (Oliver)– Q-1826, Q-1802, Q-1766B (UTHF),
Q-1766, Q-1722, Q-1705, Type 55•
Allison– C4, C3, C2•API GL-4•
Case New Holland (CNH)– MAT 3505 (MS-1209), MS-1207 (Hy-Tran
Plus), MAT 3506 (MS-1210) (TCH Fluid JIC-145), MAT 3509 (MS-1230,
M2C48C), Poclain Equipment high pressure systems, MAT 3525
(FNHA-2-C-201.00, M2C134D), MAT 3526 (FNHA-2-C-200.00 winter
grade), MAT 3510 (MS-1317, GL-4), B-6, MS-1206 (PTF), MS-1205
(TFD-II), MS-1204 (TFD), JIC-185, JIC-144, JIC-143, B-5, M2C86B/C,
M2C53A, M2C41B, M2CA/B/C, ESN-M2C77A, ESN-M2C41B, ESN-
M2C43, ESN-M2C48B/C, ESN-M2C53A/B, ESN-142A, ESN-M2C143,
ESN-M2C92A, ESN-M2C159A/B/C, Renk-Doromat 873 or 874A/B Bus
Automatic Transmission Fluid, Valtractores•
Caterpillar– TO-2•
Clark– TA 12, TA 18, HR 500, HR 600•
Dresser CED– Trans/Hyd Fluid•
Deutz-Allis– 25743, 272843•
Deutz-Fahr•
Sperry Vickers/Eaton– I-286-S, M-2950-S•
Fendt (Non-Vario)•
Fiat-Hesston– AF-87•
Ford– ESN M2C86B, M2C86C, Fiat requiring M2C134D,
FNHA-2-C-201.00•
John Deere– J20C, J20D (winter grade), J14A/B/C, JDT303,
J20A/B, J121A•
Komatsu•
Kubota– UDT/M80B•
Landini– Tractor Hydraulic Fluid•
Massey-Ferguson– M-1141 (Permatran®
821 XL, Formerly Perma-tran
®III), M-1110, M-1127A/B, M-1129A, M-1135, M-1138, M-1139,
M-1143, M-1145•
Parker Denison– HF-0, HF-1, HF-2•
Sauer Sundstrand/Danfoss– Hydrostatic Transmission Fluid•
Steiger– HTF (SEMS 17001)•
Volvo– VCE 1273.03, WB101•
Versatile– Recommended for use in Valmet, New Idea Power Units,
Leyland Belarus, Specs 23M & 24M•ZF
– TE-ML 03E, TE-ML 05F, TE-ML 06K, TE-ML 17E
INSTALLATION
AMSOIL Hydraulic/Transmission Oil is compatible with con-
ventional tractor hydraulic/transmission oils. To install AMSOIL
Hydraulic/Transmission Oil in a hydraulic system, drain the exist
ing hydraulic/transmission oil, change filters and install AMSOIL
Synthetic Tractor Hydraulic/Transmission Oil.
AMSOIL PRODUCT WARRANTY
AMSOIL products are backed by a Limited Liability Warranty.
Edited by TractorAddict 2/28/2017 17:29
(listing_pic_1200155_1462224498.jpeg)
Attachments listing_pic_1200155_1462224498.jpeg (47KB - 534 downloads)
farmindog
Posted 2/28/2017 21:26 (#5869838 - in reply to #5869196)
so how much is the amsoil?
TractorAddict
Posted 2/28/2017 21:37 (#5869876 - in reply to #5869838)
West of Broken Bow
Looks like $11.40 per quart retail. That's what the Amsoil website has it listed at. I've heard there is or was a coupon for their products, but not certain if that's only for motor oil or what.
Edited by TractorAddict 2/28/2017 21:38
fatboy
Posted 3/1/2017 00:47 (#5870114 - in reply to #5868729)
SE Nebraska
Mobil 1 15w-50 is what I have used for a few years.
farmboy78
Posted 3/1/2017 08:19 (#5870469 - in reply to #5870114)
ec illinois champaign
i had also done research several years ago when i needed to add some,i couldnt find anyone carrying the mobil,,seems to me i had a grasshopper dealer tell me thats what it was and maybe mobil even bottled the grasshopper oil,,i was going to have to get the mobil from a distributor and maybe it was only 2 1/2 gal jugs at the time,,anyway,way more than i needed,so jusy spent the bucks on the grasshopper oil
