| I have a 9430 w/ 100 ft booms, I would not mind 120 ft anymore, it would work out better for me.
I love my sprayer though. I bought it used, pull it with 4440, only issue I had was the flip over boom cylinders were giving me issues, on a higher hyd pressure tractor they worked fine, say like a 7810, but mine were just on the border line of folding or not. Called factory and worked with their techs. They were very good and helpful, and since they had a couple others that was same way, decided in my situation to go with the next size diameter larger cylinder. I found some aftermarket ones for 1/2 price, put on new hoses while at it, and best thing I did, it made a BIG difference, plus slowed the fold speed just a little, which was a good thing too.
Very happy with fold box, pump, valves etc. ( Raven ).
I would still like to have duals on mine for burndown if ground conditions would be a little soft, but then I need to change the wheel hubs according to factory OEM parts.
I dont know if I like the flange seal connections yet....they work ok, but can be a pain when reinstalling to get alignment, because of this I have changed a few things to cam lock connections to correct this, helps for washing and diagnosing, I really like the large Banjo strainers.
