Kingdom of Callaway - Fulton, Mo 65251 | They work great on dry, long stemed, densely baled hay that holds its shape with the net cut. With wet silage bales of stuff like wheat, or year old, loose bales, short hay, etc, we found the bale tends to partially come apart and drop a lot of hay right there on the knife stand, and you make a mess, especially if you then need to drive over to load in a tmr or across the pasture to bale rings.
We are going to install one on the edge of a new concrete feed mixing pad by a silage pit where we will fill a feed wagon and spills are the goal. |
