Search Forums | Classifieds (56) | Skins | Language
JD 4840 axle size
alneiowa
Posted 2/18/2017 08:12 (#5847490)
Subject: JD 4840 axle size
Ne Iowa
Does a 4840 have 100mm axles and will dual hubs fit from a 7000 series tractor? Thanks
Edited by alneiowa 2/18/2017 08:31
Jd7730
Posted 2/18/2017 12:25 (#5847961 - in reply to #5847490)
Subject: RE: JD 4840 axle size
SE MN
Yes, a 4840 is 100 mm or 4". If by 7000 series you mean a 7800, then no the axles are not the same size. The 7800 would have 92 mm or 3 5/8" axles like a 4440/50/55. A large 7020 or 7030 might have 100 mm axles though.
The dual hubs would work if you changed the sleeves.
Btw, did you get that 4840 you were going to look at?
alneiowa
Posted 2/18/2017 14:11 (#5848129 - in reply to #5847961)
Ne Iowa
I bought the second one I looked at yesterday, nice clean tractor, new rear tires, original big fronts go with it, they're barely used, QH. $15000 spent on the powershift and rear end recently, has 10000 hours, pan has been off and I'm hoping it's had rods and mains because I won't have a chance to check until next winter. Is there any other reason to have had the pan off ? Paid $17000.....all it has to do is pull 12 row planter.
Jd7730
Posted 2/18/2017 20:27 (#5848697 - in reply to #5848129)
SE MN
Sounds like a fair deal, hopefully the engine is strong yet. You could take an oil analysis to help see what you have. The typical reasons to take off the pan that I know of are bearings, oil pump or leaking gasket. As a side note, my dad bought a new 1982 4840 that I located a couple years ago that I would love to have back someday. 4840's are one my favorite JD models. It's somewhere around Waverly IIRC.
Robert W Greif
Posted 2/18/2017 15:21 (#5848231 - in reply to #5847490)
Dallas Center IA 515-720-2463
Jim
I assume you are thinking about planting with singles rear wheels at 120” spacing.
Send me a e-mail - [email protected]
(DSC06584.JPG)
Attachments DSC06584.JPG (93KB - 43 downloads)
