![](/images/spacer.gif) | |
ottertail co mn | Did you open the breather on top of the cylinder? Or the actual hydro line to the cylinder?
Did you get a manual with the planter? It explains quite well on how to cycle the cylinders.
I had a ton of problems last spring with my planter not going into the ground. I found out way more than I ever wanted to know. I needed a new master and lifts.
I had a guy come out to help, he has worked on these planters 25 years and said this was the hardest one to ever get figured out.
Hopefully yours will work after you read the book and run through the cycle process.
Also, do a search on ag talk here, a lot of good info on how to get the cylinders to work.
The proper terms of the cylinders are master and slave, some times lift cylinder works for a search also.
Good luck, email me for my number if you want to talk to me. | |
