West Chazy, New York | Jack each rafter up to straight and sister it , maybe on each side if you think the original was too light. If you can get lumber reasonable, that's the easiest way. If you think steel would work better, lag some angle iron to the side of the rafter. Get a shop to bend you some 3/16 2 by 5 angles. Heavy to put up, but won't sag like lumber will. Drill the holes in the steel first, plus a few extra holes to nail it in place to hold it, then put in the lag screws. Maybe for the hips use steel on each side and through bolt it so it can't flex. At some point you have to figure if it is worth trying to repair or just tear off and start over. |
