![](/images/spacer.gif) | |
Morris, IL | I like my 6500 with hydro. I sprayed a bit with manual transmission and pull type and i could run laps, now i think some of that is pull type but some of it is the maneuverability of hydro, stop, backup, turn, and go so much quicker. I'm all for cheap and simple, keep cost low, but it would be hard for me to give up hydro in my sprayer for covering those kind of acres, now if you were doing 300 acre 2x over i'd be all for it. I really like my sprayer for my situation, it's not perfect, ride isn't the greatest, but really is handy little rig. Turns like our Super H, very light weight, seems to do nice job. I run pre's before/after planter, then post right after sidedress, then can sprayer a fungicide or something late if wanted, even built my own Y drops for it.
Mine had a 440 but i added an Integra hooked up for auto swath, auto rate, and a lightbar. I am always following 30" rows so no big deal on steering. I do 2-3k acres a year total with it which is easy as pie, i'm also only one planting and sidedressing and do spraying when i can. I do have tender man or at least water man as i mix myself. I can work alone if needed with the tow bar and 3/4 pickup tows great, then go back for water and do sometimes. If a guy had a tandem around for grain would be great dual purpose rig to put tanks/chemical in box and tow the sprayer.
Edited by NEILFarmer 1/18/2017 21:38
(IMG_0171_2.JPG)
Attachments ----------------
