Search Forums | Classifieds (120) | Skins | Language
dry fertilizer spreader
jdcat
Posted 1/17/2017 13:44 (#5774424)
Subject: dry fertilizer spreader
Looking to purchase a used, small 5 or 6 ton, pull type dry fertilizer spreader. Was looking at possibly a Willmar but was wondering what other manufacturers were out there and what people thought were the best? Primarily spreading 11-52-0 or 46-0-0 with it. What are the key wear areas to look at when checking over a used unit? TIA
Edited by jdcat 1/17/2017 13:47
plaptown
Posted 1/17/2017 14:52 (#5774518 - in reply to #5774424)
Subject: RE: dry fertilizer spreader
Where are you located? Have one for sale
Basically whatever brand you buy, I would try to get one with a stainless steel box. And look to see if the frame is rusted out underneath. Bearings etc are fairly easy and cheap to fix
Large daddy
Posted 1/17/2017 17:39 (#5774809 - in reply to #5774518)
Chandler is well built very durable
SSeck
Posted 1/17/2017 15:23 (#5774563 - in reply to #5774424)
Central Ks
I just rebuilt a 8 ton Willmar last year. We changed every bearing just to be safe.. Check that the cross members under the spreader box are not rotted to nothing. I ended up rebuilding the whole frame under the box. Check that if it has brakes that they are functional or not a problem. All in I believe we spent a few thousand on new bearings, misc parts, and steel to get it back to running.
On a side note, you can buy any individual part on a Willmar if you get with your dealer. If it is a piece of bent metal, they will be able to order it. As a Deere guy, I was very impressed with AGCO on that one...
BBfarms
Posted 1/17/2017 15:35 (#5774586 - in reply to #5774424)
SE Michigan
Have a Tyler, SS box and apron chain. Rest of the frame is regular steel, mostly re-plated or patched by me or the previous owner. I needed new spinners a few years ago, after some searching on the net I found a place in the south that I was able to get parts. Most of the other replaceable things are common that can be found at most any farm supply "box store" over-all pleased. Based on what I have in it now, and the acres I spread, it is paid for. However due to time issue in the spring (one man operation) I have the local CoOp spread 80-90% of my needs.
DixieDeere
Posted 1/17/2017 17:38 (#5774804 - in reply to #5774424)
Jackson County, AL
We've always had Chandler.  BBI is a similar unit.  Newton Crouch seems to be more of a Cadillac and we hear very good things.  I know with Chandler bearings are all standard sizes and can generally even get them at our Deere dealer at as good a price as anywhere.  Local industrial bearing place even carries extreme duty very high quality but you pay for it.  Chandler is close to us so can get stuff fairly quick.
coastalBend
Posted 1/17/2017 19:48 (#5775144 - in reply to #5774424)
south texas
I use a doyle from Helena every year on 1400-2000a. Its usually trouble free but i don't take care of it in the off season. Holds 4.5-5 tons
http://talk.newagtalk.com/forums/thread-view.asp?tid=531700&posts=1...
BartS
Posted 1/17/2017 20:51 (#5775349 - in reply to #5775144)
Southern Colorado
It would be a plus if the drive chain has hydraulic engagement instead of a rope pull. I have to admit that this is all based on 5 ton Wilmar spreaders, I don't know what the other brands use.
coastalBend
Posted 1/17/2017 21:06 (#5775397 - in reply to #5775349)
south texas
The doyle has belts and gear box. Can be activated by hydro or manual.
Antreis
Posted 1/18/2017 00:17 (#5775666 - in reply to #5774424)
http://talk.newagtalk.com/classifieds/Classified.aspx?id=66025
