Case 580 e backhoe steering problem
angus man
Posted 12/17/2016 04:38 (#5703439)
Subject: Case 580 e backhoe steering problem
N E Illinois
Used machine about a week ago. Started it yesterday and the steering wheel is frozen i.e. Won't turn a bit. What do I need to do?
garywi
Posted 12/17/2016 06:23 (#5703507 - in reply to #5703439)
Subject: RE: Case 580 e backhoe steering problem
franksville wi
Does the loader go up and down? Looks like shaft from steering wheel is one piece with the valve
(IMG_1566.PNG)
Attachments IMG_1566.PNG (136KB - 468 downloads)
angus man
Posted 12/17/2016 08:23 (#5703713 - in reply to #5703507)
N E Illinois
Hydraulics work. Worked fine when driven in shed a week ago
shopmanbob
Posted 12/17/2016 12:23 (#5704156 - in reply to #5703439)
Do you have a cab? If not, it may be rain water have gotten into the column and has frozen. Has the temp. turned colder where you are since you last used it.
Illini Fan
Posted 12/17/2016 23:13 (#5705634 - in reply to #5703439)
Greene County, Illinois
Low on hydraulic oil?  Steering is the first to go.
