Search Forums | Classifieds (56) | Skins | Language
Skid steer brush cutter recommendations?
aqf
Posted 12/13/2016 15:54 (#5695486)
Subject: Skid steer brush cutter recommendations?
WC Illinois
We are looking into a rotary brush cutter to put on our New Holland C232 tracked standard flow skid loader. First off, will we be happy with the performance putting this on a standard flow machine? Mainly wanting to clear field edges of scrub brush and some clearing of undergrowth.
Seems to be a lot of companies out there making the rotary cutters...do any of them stand out above the rest? Any recommendations/things to look for/avoid? TIA
madcow
Posted 12/13/2016 16:18 (#5695519 - in reply to #5695486)
Subject: RE: Skid steer brush cutter recommendations?
SCIA
diamond
s205
Posted 12/13/2016 20:55 (#5696229 - in reply to #5695519)
Fayette Co, Iowa
I used a diamond for a demo on my bobcat 205, standard flow. I believe it was a66 inch not a 72. And it was about right for size wise. biggest thing I chewed up was a 8 foot tall willow. The downfall is its heavy. Reason being its a heavy built mower.. I would own one in a heartbeat but 9,000.00 is not in my budget for a front mount mower for a skid loader..
DBW
Posted 12/13/2016 17:42 (#5695651 - in reply to #5695486)
West Central,WI
I have the Diamond rotary head and been very satisfied with what it can do. It definitely cost more but very heavy built and worth the money. Also they're a great company to deal with
iseedit
Posted 12/13/2016 17:52 (#5695672 - in reply to #5695486)
central - east central Minnesota -
aqf - 12/13/2016 15:54 We are looking into a rotary brush cutter to put on our New Holland C232 tracked standard flow skid loader. First off, will we be happy with the performance putting this on a standard flow machine? Mainly wanting to clear field edges of scrub brush and some clearing of undergrowth. Seems to be a lot of companies out there making the rotary cutters...do any of them stand out above the rest? Any recommendations/things to look for/avoid? TIA
Diamond is good, but pricy - They are a heavy duty, heavy use commercial type cutter.
Brush Wolf is a heavy duty reliable unit. Price less then Diamond. Worth considering. http://www.brushwolf.com/
Possible this company also - http://www.erskineattachments.com/
TOM/MN
Posted 12/13/2016 18:02 (#5695693 - in reply to #5695672)
scmn
When you guys cut brush do you leave the glass door in or put a plexiglass or whatever they are called in?
iseedit
Posted 12/13/2016 18:27 (#5695759 - in reply to #5695693)
TOM/MN - 12/13/2016 18:02 When you guys cut brush do you leave the glass door in or put a plexiglass or whatever they are called in?
I prefer glass . . . .  plexiglass scratches too soon and too much. Glass can take a pretty good hit and still clear. I've gone throw about 9 glass pieces for my skidsteer. Only had one plexiglass and never again.
Edit: A few of those "hits" would have taken the plexiglass out also - branch poked through glass . . .
I use laminated glass also - not tempered.
Edited by iseedit 12/13/2016 18:29
(PC130433.JPG)
Attachments PC130433.JPG (126KB - 545 downloads)
VermeerTech1
Posted 12/13/2016 21:45 (#5696349 - in reply to #5695693)
We just use the OEM glass door. On our Gehl R220
rollinsorchards
Posted 12/13/2016 18:02 (#5695694 - in reply to #5695486)
Garland Maine
I rented a standard flow Bradco Ground Shark this fall, and was impressed with what it would do. On medium sized stuff it will leave stumps that look good for tire puncturing. I tried it on standing trees up to inch and a half diameter and it worked well, and cleaned up brush piles with some three to four inch pieces in them, admittedly brush piles were a year and a half old.
I like the prices of the ones at Unlimited Fabrication in North Carolina at www.rootgrapple.com , but have not bought anything from them yet. I think I will order one of theirs this winter unless someone on here has had a bad experience with them.
For a big project using a brush cutter more than a foot off the ground I think I want a good Lexan forestry door. I got by with just tilting the mower up away from the cab on my small project.
tooth and nail
Posted 12/13/2016 18:13 (#5695718 - in reply to #5695486)
Depends on how big of stuff you want to cut
I have the Diamond Forestry head it will turn a 6" tree into mulch in about 5 seconds( also surprisingly good at mowing grass)
Can cut a tree up to about 14"
It DOES require a high flow, and 90+ HP, mine is 92 hp and 36 gpm wouldn't want any less.
From this
to this
Bob Long
Posted 12/13/2016 18:28 (#5695762 - in reply to #5695718)
SE Mich.
"It DOES require a high flow, and 90+ HP, mine is 92 hp and 36 gpm wouldn't want any less."
Does it require an auxillary hydraulic oil cooler?
(I've observed auxillary oil coolers on the roof af Cat and ASV units when equipped with a 6' forestry mulching head.)
tooth and nail
Posted 12/13/2016 19:26 (#5695933 - in reply to #5695762)
Bob Long - 12/13/2016 17:28
I have not used it in the heat of summer, got it in Sept. Haven't had any overheating problems , Bobcat 770
DBW
Posted 12/13/2016 19:09 (#5695886 - in reply to #5695718)
West Central,WI
This is what a the Diamond rotary head can do too. Been thinking about getting the forestry head that Diamond makes too.
(IMG_20161201_141231255_HDR.jpg)
(IMG_20161201_134353637.jpg)
Attachments IMG_20161201_141231255_HDR.jpg (452KB - 471 downloads)
Attachments IMG_20161201_134353637.jpg (431KB - 510 downloads)
TWB
Posted 12/13/2016 20:38 (#5696175 - in reply to #5695486)
Middle Tennessee
I brought a Blue Diamond 60 inch HD rotary cutter last year.
My cutter has 3 blades and standard flow hydraulic gearbox.
I vote for Blue Diamond
VermeerTech1
Posted 12/13/2016 21:40 (#5696335 - in reply to #5695486)
+1 on Brush Wolf,
Cross tech MFG is top notch. Quality is as good or better than Diamond Mowers. IMO I have ran both and like both. If you have a dealer for either one close you can't go wrong. I personally bought a 72" brushwolf and run it on 19 GPM and it's great. I use it for fence lines, and clearing buckthorn mostly.
sonnefarms
Posted 12/14/2016 14:31 (#5697461 - in reply to #5695486)
Standard hydraulics will be fine with a brush cutter. You really don't need high flow unless you are running something like a cold planer. This is how John Deere's products are set up anyway.
BDA
Posted 12/29/2016 06:51 (#5729454 - in reply to #5695486)
you may want to check this out.
http://www.bluediamondattachments.com/open-front-brush-cutter/
