SC Wisconsin | I'm having issues with my battery light coming on and off on a F725 Front Mower I bought as a project. This has a Kawasaki FD592v in it. The battery light will be off after I start it, but will start flickering after 1-2 minutes and will be solid after 30 minutes to an hour. I'm getting 39v AC across the stator leads, and 13.6-14.1v DC across battery at full throttle. I've measured it when the battery light is on solid and not on at all. Similar results.
My limited understanding of the Kawasaki voltage regulator on this is that it compares voltage on the battery charge line to what's coming back from the keyswitch. If there is enough difference, it sends a signal to the battery light. I won't say that's gospel, but what I found on a post in a different forum while searching.
I worked through all the troubleshooting steps in the Deere technical manual (see below) and it passed all them. I've cleaned all connections in the charging circuit, cleaned up the grounds, and installed a new key switch and regulator. The key switch failed the troubleshooting test, even though the tractor ran. The regulator was a "please let this be what fixes it" hail Mary attempt. It didn't. The battery is also new, because the old one was trash when I bought it.
I have a Kawasaki technical manual for this engine, and there is one additional Ohm test in there for the stator itself. The ohms across my stator leads are a bit high. They are 0.6 vs 0.11 to 0.18 per the service manual. So we might have an issue there. Neither lead shows continuity to ground. But I'm hesitant to throw $150 at a new stator and pull the flywheel unless I'm dead sure that's the issue. It seems to be putting out enough AC volts, per the manual, but maybe there's something deeper I'm missing.
I'm stumped! I'd appreciate any thoughts you'd have. Or other troubleshooting steps I could take.
(Diagram_zpslc245e9x.jpg)
(Test_zpsxiwmwjjy.jpg)
Attachments ---------------- Diagram_zpslc245e9x.jpg (110KB - 699 downloads) Test_zpsxiwmwjjy.jpg (155KB - 648 downloads)
