NC Iowa | I've had all three. Nothing will get it blacker than a 2730. If you have enough horsepower to put the disc in the ground. Its the only thing I have ever seen where the disc blades will just keep going deeper and deeper. If you have your shanks set at 10" depth with a 9560RT and 11 shanks, the disc is really the limiting thing on horsepower. If you take all the collars off and bury the disc it will slow you down to nothing but it will make it almost as black as plowing. If you want to keep your speed at 5.5 to 6 you'll have to set the disc at a reasonable depth like 3 or 4 inches which then makes it comparable to an 875. The leveling is better on the case ih, it will leave it smoother no matter how you try to set the john deere. This is in heavy black dirt. If you are in a different part of the country, someone might be able to go 7 mph at 14 inches. I've never really liked the shanks on the deere. It doesn't seem like there is any sweep forward to them like the dominator or case ih. The points on the other two are pointed forward a little bit, and might do a little bit of lift and twist. The deere is like the point is facing downward and basically like dragging a stump underground. | |
