| There are several 6500s in this area and a couple 6700s. We have run a 6500 for 3 years and have gotten along fine with it though did have an o-ring go out on one wheel motor but it was a simple in the field fix.
Not positive but I think the later 6500s had more hp than the earlier ones. One of the guys that has a 6700 had a 6500 previously & he complained it was short on hp & that was why he traded for a 6700. I have noticed a lack of power with ours. I usually spray 11 mph in Hi on the 2speed hydro & that's with the throttle set at about 3/4. Haven't had any problems maintaing a constant speed, even on slighly rolly ground, unless it's muddy. Back in June after the big rains I powerd out in some spots & had to drop to Lo on the hydro but that was in reall muddy condition & the tires were sinking enough that the fenders were dragging.
Besides what other have mentioned in differences between the 65 & 6700s the 6700 is equpped wth a T tank, 6500 has an oval tank, but the T tanks is slightly smaller, 415 gal compared to the 65's 420 gal. ^700 has front fill & the 65s have rear fill.. Presonally, I like the rear fill because I back up to the water truck & everything is just a few feet away where I can see what's going on instead of at the other end of the machine. Maybe not important to some but it sure makes a difference to someone like myself that doesn't have the best set of wheels under them. | |
