EZ-guide 500 power cable pinout
mackg
Posted 7/7/2016 21:29 (#5398429)
Subject: EZ-guide 500 power cable pinout
West Central Ohio
I picked up a used ez-guide 500 from a fellow ag talker here. It included the 62817 cable which is needed for EZ-steer, but not the 62818 lighter plug cable. I am going to be using it without ez steer so was going to make a power input cable to plug into the 8-pin deutsch connector but cannot find the pinout anywhere. There are (2) whites, a blue, a yellow, an orange, and a red/white. Only the blue and (1) of the whites have continuity to the 5pin branch that plugs into the power port on the back of the ez-guide. I was gonna try these but afraid of frying the display and was hoping someone could confirm. TIA!
neo_ag
Posted 7/8/2016 05:37 (#5398858 - in reply to #5398429)
Subject: RE: EZ-guide 500 power cable pinout
northeast ohio
The 62817 is the fused power for both the display and ezsteer. It is common practice to run a pair of power wires from the battery, through a toggle switch and to a 2 pin deutsch to connect to the 62817. This provides clean power if you ever add an ezsteer and / or ezboom.
Edited by neo_ag 7/8/2016 05:40
(image.jpeg)
Attachments image.jpeg (86KB - 882 downloads)
mackg
Posted 7/8/2016 06:25 (#5398904 - in reply to #5398858)
West Central Ohio
My cable did not have the 2 pin connector you mention so I did some research and belive the cable that I have is actually a trimble 62063 (connects the 500 to navcontroller autopilot). It has a 4 pin deutsch (P2 Can EZ Boom) and an 8 pin deutsch (R3 Cntrl GPS) as well as the P1 EZG500 and P4 EZG500 which both plug into the back of the 500. My goal is to make a fused cable to plug into one of the detsch connectors and utilize the existing 62063 cable that I have. thx!
(IMG_0161.JPG)
Attachments IMG_0161.JPG (91KB - 795 downloads)
neo_ag
Posted 7/9/2016 07:15 (#5400819 - in reply to #5398904)
northeast ohio
Comparing this cabling guide to others it appears that your 62063 is a combo of the 62817 (power) and a 62609 (port exp). The 4 pin would appear to be the power supply connection. Maybe the ezboom connects on the 4 pin between this and the fused power. An ezboom would also receive power from the Raven harness. I am making plenty of assumptions based on this and other diagrams. Can you ask the original owner how the power was supplied?
http://trl.trimble.com/docushare/dsweb/Get/Document-355989/EZ-Guide...
Edited by neo_ag 7/9/2016 07:18
(image.jpeg)
Attachments image.jpeg (201KB - 810 downloads)
mackg
Posted 7/9/2016 17:15 (#5401656 - in reply to #5400819)
West Central Ohio
AhHa, Thanks for the diagram. Now I at least know what I am dealing with. I am now trying find someone in the neighborhood with a 500 (no steering) and a std power cord that I can ohm out from the lighter plug to the small 5 pin round connector that plugs into the back of the 500, or find someone on here willing to do that and ID which of the 5 pins go to the +12v and ground on their lighter plug. Kinda funny how trimble & AL show pin-outs of the rs232 in the user guides, but nothing on power pin outs or even color codes. I guess I should just fork out the $150 to buy one, but that seems silly when I have everything I need, except the knowledge of which pins on that little connector I need to hook to. Seems to be lots of 250's and 750's around here but no luck on a 500 so far. Thanks!
neo_ag
Posted 7/10/2016 06:45 (#5402418 - in reply to #5401656)
northeast ohio
Found the graphic with the ezboom connection on the agleader site. No power connection on the 4 pin deutsch. Actually doesn't show power anywhere.
(image.jpeg)
Attachments image.jpeg (121KB - 860 downloads)
abordone
Posted 1/10/2017 23:29 (#5759502 - in reply to #5402418)
SW Indiana
Nt
