Central, WI | I thought it was a crazy question at first but I figured what the heck and thought I would ask all the fellow NAT'ers. My neighbor stopped by and got me thinking about it yesterday. He has a smaller 4wd on his tile plow right now, about 25,000lbs, but needs a little extra pull sometimes to get thru tough spots when going over 4 feet laying 6" tile. This is on mostly flat land, non-worked corn stubble and hay field ground and ideal dry tile conditions. He has a 65,000 lbs base operating weight front end loader with an 855 Cummins Big Cam in it. He could add more weight inside the 7 yard bucket if needed also. He has 29.5R 25 rubber on it with very deep tread, almost new L3 rubber. Could a guy use this loader to help pull the plow thru tough spots without the worry of it getting stuck on mainly dry ground or hurting something on the loader over time?
I found a previous post about Sandusky Tile in Michigan using a larger Clark/Michigan loader with clamp-on 20.8x38 duals added onto each axle. I never saw a picture of it but figured it could be done and if he got real ambitious he could use triples and maybe even pull the plow directly with the loader. It would have more than enough hydraulic capacity (92gpm at 3100psi) to run the plow hydraulics and it would be ideal to ease into start holes using a loader tranny. He would have to add a third valve possibly. 65,000 lbs and considering it is a piece of construction equipment it should hold up a lot better than a similar weighted ag tractor over time. I told him to not call me when it gets stuck because there is no tractor big enough around the local area to pull him out..LOL
Edit: found this photo but not sure if it the one from Sandusky Tile mentioned previously.
Edited by Farmer8920 7/2/2016 09:08
(Zor tile plow on wheel loader.jpg)
Attachments ---------------- Zor tile plow on wheel loader.jpg (63KB - 305 downloads)
