Search Forums | Classifieds (41) | Skins | Language
Best treepuller?
4055
Posted 4/8/2016 17:59 (#5230715)
Subject: Best treepuller?
W.C. Ohio
Trying to make a decision on a tree puller. I think I've narrowed it down to an Intimidator from Danuser or the EZ puller XL Pro from CL Fab. Really like the grapple/cab guard on the XL Pro and looks very well built, but pricey. The Intimidator looks solid as well, and I like the teeth on top for help in cutting thru roots on bigger trees also. Never seen either in person just pics and video on the www. not sure of price on the Danuser but CL's was on their website. Both have a 34" opening. Says 3" cylinder on the Danuser not sure on XL Pro their smaller model says 2.5". Does anyone have experience with one or the other? Pros or cons? Would be mounted on a Case 450 series 3 if that makes a difference. Rubber tired machine.
wishbone7803
Posted 4/8/2016 18:14 (#5230737 - in reply to #5230715)
Subject: RE: Best treepuller?
Almond Wisconsin
Best one I've seen is from NOTCH mfg. On our track machine it is a beast! http://www.notchmfginc.com/treepuller.html
Edited by wishbone7803 4/8/2016 18:20
4020panther
Posted 4/9/2016 10:44 (#5231998 - in reply to #5230737)
Center Valley Wisconsin
Have a NOTCH on a lx885 new Holland. Got steel tracks on skid steer for traction and extra weight. Very happy with the NOTCH tree puller.
JB59
Posted 4/8/2016 18:28 (#5230760 - in reply to #5230715)
NW OHIO
Come on over and check mine out. (near Lima Oh)
http://www.gripnriptreepuller.com/
Edited by JB59 4/10/2016 15:22
(Tree in tree puller.jpg)
Attachments Tree in tree puller.jpg (177KB - 348 downloads)
LNS8310
Posted 4/8/2016 20:24 (#5231008 - in reply to #5230760)
N.C. Iowa
Looks like an awesome machine, what does it cost?
meyer
Posted 4/8/2016 20:25 (#5231016 - in reply to #5230760)
Bluffton, Ohio
I will first disclose that JB59 is my father in law, but honestly I do not feel I am being biased when I give it a review. It is a great tree puller that works very well. You need to watch a video https://www.youtube.com/watch?v=fJUuBWOaso0 of it working to get a feel for how easy it does the job. The scooping action is what makes it different than the others. After you use it for a while you get the hang of how to use the scoop to give you a huge mechanical/hydraulic advantage over just trying to pinch a tree and pull it out with the skid loader. The scoop shears the roots and loosens up the dirt to allow the tree to be removed. It is a new product, but truly feel that if a few of you guys on here get to use it, you would agree that it can pull larger trees than the others on the market while putting less stress on your loader. Take time to check it out- from using personally on my farms, I highly recommend it!
braidy
Posted 4/11/2016 08:57 (#5236238 - in reply to #5230760)
NW Minnesota
I like that, what is the ballpark price?  The grip n rip I mean.
Edited by braidy 4/11/2016 08:58
3w farms
Posted 4/8/2016 19:01 (#5230822 - in reply to #5230715)
S.E. Iowa
Remlinger make a tree /post puller originally built and designed by PFM works great
Angus8335
Posted 4/8/2016 19:32 (#5230875 - in reply to #5230715)
Galena IL
Got a Deere 200LC with a hydraulic thumb that works really well $42500 and its yours... Dennis
kbg
Posted 4/8/2016 20:10 (#5230965 - in reply to #5230715)
Central Indiana
We have a XL Pro from CL fab and its great! We have it on a Bobcat S650 and I'd be more worried about tearing up the machine before the puller. Doesn't ever slip the only thing that limits the pulling is the capacity of the machine. We had to put a restrictor inline to slow down the opening/closing speed.
JB59
Posted 4/8/2016 20:20 (#5230992 - in reply to #5230965)
NW OHIO
kbg, that is why mine works so well, gripping the tree at first is meant as an anchor. Then you sweep the scoop under the tree cutting the roots. Then carry the tree away with the grippers. Now you don't need such a large skidloader.
PSI is your friend.
crowbar
Posted 4/8/2016 20:14 (#5230978 - in reply to #5230715)
Hazelton, Kansas
Toby,
I have a CL XL Pro with a brush rack (not the grapple). I've probably taken out 5 miles or so of fence, and loaned it out for probably another 5 miles or so. Once the wire is off, you can have one person just idle along in the dump truck, while the skid pulls the posts and puts them in the truck.
I'm satisfied with mine, but I'm easily impressed, having grown up pulling posts with a three point hitch and a log chain.
No experience with any of the others.
MDS
81IH1086
Posted 4/8/2016 20:25 (#5231011 - in reply to #5230715)
I'd recommend everyone to check out www.gripnriptreepuller.com This tree puller is Awesome it is different than any other tree puller I have ever seen. Last spring we used it to clean near a waterway. I was so impressed.
dondozer
Posted 4/8/2016 21:14 (#5231152 - in reply to #5231011)
NW Ohio,near Findlay
Agree with you, Jon let us run the Grip and Rip on a Deere skid steer a few days, did a great job.
Poor farmer
Posted 4/8/2016 22:46 (#5231380 - in reply to #5231152)
Martinton,il
I have a CL Fab and like it a lot. It has 1 inch teeth and a cover over the cylinder that makes it almost bulletproof. I have it setup on my loader tractor and it can make quick work on a half mile of fence posts.
What does that grip and rip puller cost? It is amazing. And how heavy is it?
Edited by Poor farmer 4/8/2016 22:51
