Pierce county WI | I have always had my own combine, even when I only farmed 170. Wisconsin and Pennsylvania have field size in common. So these guys out west don't run in the same conditions as a farmer from pa. Here's how I figure it: it's not cheaper to own a combine. It's not anymore expensive. But, if you're like me, and drying it yourself, it takes time. A custom guy wants to do it all in one shot. I will guarantee this, it's way cheaper to dry your own. Then there's the issue of beans. I've seen guys wait for a long time to get they're beans combined, because of mother nature not cooperating. There was a perfect window to harvest and the custom guy was doing someone else's. And on the flip side, I've seen beans drop moisture in two days that could pay for the combining of you couldve cut them at the ideal moisture. You must like machinery, I think that's half the reason some of us farm. Anyhow, as far as a combine, I had good luck with my 4400, 6620, and 7720 titan 2. The parts availability for older Deere combines around here is second to none. However, I'm going to say skip the 7720 and go for a 9500. I bet you could buy a decent one somewhere for not much more than 15k. I traded the 7720t2 on a 9510 last fall, and it's frickin sweet! Probably more combine than I need to combine 250 acres, but it works for my farm. Good luck, at least combine shopping is a fun job. | |
