Search Forums | Classifieds (2) | Skins | Language
John Deere 7000 planter advice
goosehunter1
Posted 2/18/2016 11:55 (#5120269)
Subject: John Deere 7000 planter advice
Looking into buying a JD 7000 4 row planter and was wondering what I should be looking out for. Which parts typically go bad
and what exactly I should look for. Any input is greatly appreciated!
James
Gerald J.
Posted 2/18/2016 13:28 (#5120424 - in reply to #5120269)
Subject: RE: John Deere 7000 planter advice
The fastest wear points of the 7000 planter are the gauge wheel arm pivots and the pivots for the tail piece. Opening disks wear too. Drive chains wear or rust rigid from inactivity. I had to cut some off of mine, those for the insecticide and herbicide boxes out back. The bearings for the drill drive shaft (hex shaft) wear. Worn gauge wheel arm bushings let the gauge wheels flop. There are replacement parts from Deere, Shoup, and the best ones from RDK.
Finger units wear the fingers and the back plate. Bean cups are irregular and so expensive to run, Kinze brush units, Deere brush units and Shoup brush units are all reported to work. I know the Kinze work very well because that's what I have on my 4 row. The drop belts wear and the seed tubes wear. The lenses on the monitor detector eyes get frosted from seed dragging on the. Sloan had the best price on those the last I bought about 10 years ago.
The steel line for the marker inside the main tube rusted through because of mouse liquid excrement. The seals in that cylinder can wear but aren't expensive to replace, just inconvenient.
Everything that moves does wear but by now most should have been replaced once. My 7000 was delivered in 1974 so its been around a while but it set a planting quality that modern expensive planters try to do as well.
Gerald J.
paul the original
Posted 2/18/2016 14:26 (#5120508 - in reply to #5120424)
southern MN
What Gerald said.
Often a mouse builds a nest inside the square frame, and this will gum up the automatic marker mechanism, as well as rust out the oil line inside the tube to the right side. Not big deals, but something to check out before you hit the field.
Precision Planting has some 'better than JD' corn meters and seed tubes if you need to totally rebuild yours. Something to consider.
The parallel arms holding the row units to the main beam get egg shaped pivot holes, Shoup and others have bushings or new arms to deal with that. Lift up the back of the row unit and see if it is pivoting in worn holes.
Paul
Mgdoug3
Posted 2/18/2016 17:05 (#5120759 - in reply to #5120424)
Central-ish KY
Good Advise. Only thing I would add would be to check the seed tube guards and down pressure springs. If the seed tube guards get worn down to 5/8" at the bottom, they need to be replaced. Unless you're planting in worked ground, you'll want the heavy down pressure springs. The John Deere ones are good and so are the Yetters with pin adjust. The good thing about a 7000 is that parts are easy to find and get. I'm partial to Shoup for parts. Free shipping over $200 and usually get parts the next afternoon or two days at the latest.
jd43
Posted 2/18/2016 13:34 (#5120434 - in reply to #5120269)
Northeastern Pa.
I am not sure where you are located but in this area here is what I look for. Cracks on the seed unit assy. above the depth wheels on both sides. Cracked closing/tail wheel assy. Broken closing wheel tension spring. Unit down forces springs. With the planter raised lift up on the seed units. Should be fairly tight and no side to side movement. Open hoppers and make sure there is no left over seed as this causes seed backing plate rust. Seed opener disks no less than 14.5 inches. Wheel bearings. Then the normal wear items like drive bearings and chains. If you buy one the operators manual is your best friend.
baccerfarmer
Posted 2/18/2016 14:15 (#5120490 - in reply to #5120269)
Hallsboro NC
Another thing to think of is what row spacing you want. unless its a conservation (7x7 bar with independent cylinders on each wheel to raise and lower) 36" is as close as you are going to get. you can do some cutting and welding to go to 30" if you want to, that is what I did and it works great. Excellent planters most any part can be ordered from shoup, a lot cheaper than from deere.
chadlit
Posted 2/18/2016 14:49 (#5120541 - in reply to #5120269)
SD
What are you going to be planting with it and how many acres?
Kmk302
Posted 2/18/2016 19:34 (#5121173 - in reply to #5120269)
Reading, PA
I have a 7000 Conservation with 2000 acres on it. Always barn kept and well maintained. 4RW, can be made into a 4RN easily
Trent2520
Posted 2/18/2016 20:18 (#5121309 - in reply to #5120269)
Subject: If you want a new planter cheap,
Statesville, NC
Find a 7000 frame and wheels. The rest can be junk. Order your choice of 7000 or 7200 units new from Shoup. They have the complete units, less the meter, box, and drive. They have those too, just separately. http://www.shoupparts.com/R1050/
chadlit
Posted 2/19/2016 13:06 (#5122676 - in reply to #5121309)
Subject: RE: If you want a new planter cheap,
SD
Just find a good planter and replace parts on the row unit as needed. Row unit cost is over $1,000 per row unit assembly and its not even complete. You can buy a lot of parts for $1,000/ row.
