ktripberger - 2/16/2016 14:02 I have done some digging around on it today. There is only one speed sensor with two outputs, I have switched them back and forth and the speedometer reads fine on either output. I have checked the continuity on the wires from the speed sensor to the ECM and I have continuity on one output. Both wires from that output have continuity to the ECM. I tried every variable with the On/Off switch, held my foot up on the clutch switch and still nothing. I believe I am real close to a total loss on this one. Thanks for your help guys! ktripberger - 2/16/2016 08:02 I am almost at a loss. I have a 2000 Freightliner Classic and I can not get the cruise control to work for nothing. When I am sitting at an idle, it will work to increase the idle, but as soon as I start driving it won't work. The jake brake still works, which should mean that my clutch switch is operating properly. I have replaced all the brake switches. I have switched the speedometer wires coming out of the transmission. I have also switched out the ECM with a neighbor that I knew the cruise control worked on his truck and still nothing. I have no idea what else to try or even check. Any help would be greatly appreciated, before I have to take it to the dealership and have them check it. I would love to avoid that cost. Thanks! ___________________________________________________________________________________________________________________________________________ Ok. I copied and pasted your first thread, so I can see everything on one page. First, have you owned the truck, when the cruise control actually worked? (or is this truck "new to you", and you just purchased it?) What brand of engine? Is there a PTO switch, on this vehicle or dash? The two wires, between MPH sensor and the ECM; Were they twisted together? (or has someone just throw on different wires and they aren't twisted) = they need to be twisted (they call them a "twisted pair"). On your first post you said = it will increase idle {Does that mean, after you release the cruise "set" button/rocker switch, does the engine maintain that certain RPM, sitting still ? Example: it maintains 1250 rpm or whatever, with your hands OFF the dash switches?} or does it drop back down, in rpms? |
