Wisconsin | Hello all- I've done quite a bit of reading on some of these questions, but wanted to get some feedback on if you would do it again, or how you'd do it different... thanks in advance for the input...I'm looking for it.
We have an old 4230 John Deere that is apparently staying around for a while, so we have brought it in the shop for some work. Currently on the list of To Do's is: AC, Radio, Cab Kit, Seat, Roof, Door...
AC- it has the old R12 compressor still on it- was thinking of ordering that complete line and compressor kit from Abilene Machine- has anyone used it, and would they do it again? Is their a better source? $700 for lines and all seemed dang reasonable... http://www.ebay.com/itm/New-AC-Compressor-Conversion-Kit-R12-to-R134a-John-Deere-4030-4040-4230-4430-/251505812898?hash=item3a8eea25a2:g:8dEAAOxy0x1TTU~C
Radio- it is an old 4230- two rear speakers- both out in this case- what is a good source for those? Is OEM the best route? I believe the head unit to be fine.
Cab kit- I'm apparently beating a dead horse here- is this tractor worth putting a material down before the cab kit- for noise and insulation dampening? I am down to bare metal right now so there's no time like the present I guess- the materials I looked at are the "Dynamat" style.
Seat- like I said it's old- no hydracushion here- old suspension yellow-pretty much a 20 series seat- we thought about an upgrade- some don't seem to think that the air was a good idea- is that still accurate? What is a good solution for this? original? Shoup has this one...its on the high side for my budget, but I'd like some feedback first. http://www.shoupparts.com/DR440/ Roof-current one is old and cracked beyond any repair- are all of the replacements the same? Anyone had a bad experience or should I just pick one and go with it? Door- Current one has been bent and welded- time for a new one- what is the best route- anyone satisfied with one more than the other? OEM best? Thanks again. |
