I currently have a JD 750. I used to have a D6B and there is really no comparison in power or ease of use, the JD wins easily. As someone else pointed out, a D6C would be good and D6D better. As far as the 750 goes, I have to say I really like it. Plenty of power and very nimble. The hydrostats work great. Mine are getting a little on the worn side but I have a spare set that has been rebuilt sitting on the rack in the shop. Just waiting for the day when I feel very like doing it. The 750 starts easy and does everything I need it to do. Parts are readily available through various sources. I have had and rebuilt several dozers over the years. One thing that you will find when you tear into them is that there is always a lot more work to do on older dozers. As you tear them down, you find other things that should be fixed while you are in there. Email is good if you have any additional questions. |
