Search Forums | Classifieds (104) | Skins | Language
New to laser leveling
Frankiniowa
Posted 1/29/2016 20:48 (#5073656)
Subject: New to laser leveling
Need some beginners info to laser leveling, dual slop vs single auto or manual controls, the different mast types and brands not much info on the web for somebody that doesn't know the basics. I see some dozens working on roads sometimes with two receivers on the blade what's the purpose of two, I am looking to put a slop on some 40 acre fields that we irrigate to help the drainage. Thanks.
Now_What
Posted 1/29/2016 21:22 (#5073759 - in reply to #5073656)
Subject: RE: New to laser leveling
The reason why you would see two recievers is typically for each end of a motor graders blade.
Dual recievers would also be used to control each end of a wide box scraper as used in ag laser finishing. With a wide box scraper one end would tend to dig in and the other end would dump dirt when making turns or crossing rough ground.
I have a single slope and dual slope laser the single slope is good for making a straight ditch or trench. In field leveling you end up with two options with a single slope laser.
1 you have extremely flat land with no side fall and only main slope in the direction the rows follow.
2 The other option with a single slope laser is you have to rotate the laser the right amount of degrees and then enter a compound grade into the laser.
For example you have .2% main fall and .2% side fall you would rotate the laser 45 degrees from the main fall up towards the side fall and then enter a grade of .28%
If you are just draging dirt into low spots without re doing the whole field I would recommend a dual slope laser with a remote as you will be having to keep playing with things to get everything to match up.
Here is a picture of the difference in lasers.
Edited by Now_What 1/29/2016 21:57
(image.jpg)
Attachments image.jpg (30KB - 263 downloads)
Now_What
Posted 1/29/2016 21:55 (#5073835 - in reply to #5073759)
Here is a box scraper with dual recievers https://m.youtube.com/watch?v=CvQQBEmAzUw
Frankiniowa
Posted 1/29/2016 22:04 (#5073865 - in reply to #5073835)
I am planing on using a 14 foot box scraper is that too wide for a single recover, I am just a hobby farmer so I have the time, one of my bigger questions is when go beyond the range of the laser what is the process of moving the laser and getting back to.the same grade it seams simple for single grade but dual grade is confusing me
Now_What
Posted 1/29/2016 23:12 (#5073996 - in reply to #5073865)
14' should be fine with a single reciever and wider you would want a seperate control for each corner.
The dual grade is much simpler to move than a single grade. The dual grade you just have to align one axis with your field and then dial in the main and cross fall in your field.
With a single grade it's a pita to move the laser doing open field grading and getting it to match up as you have to align the laser with the direction of the compound grade.
Many times you move the laser over and the grade will be spot on in one axis but the side fall might flatten out or there might be a drop off and you will have to dial in that one axis. With a single slope even with one axis lined up you will have to sit down and re calculate the compound grade and the angle that you need to rotate the laser. If you are doing a ditch r trench it doesn't matter as much.
I have cut a ditch with the carryall and just aligned the dual slope laser in the direction of the ditch and entered 0 for the other grade.
With a box scraper you will need the fields close to on grade to begin with. It takes a while to drag a few inches of dirt off a hill with a box scraper.
Edited by Now_What 1/29/2016 23:14
twraska
Posted 1/30/2016 09:27 (#5074487 - in reply to #5073996)
Wallis, TX
 +1 on the dual slope transmitter, one with a remote is helpful when 'touching up' parts of a field.
